> Info For 915 Axle Conversion, Pictures
914Sixer
post Apr 13 2023, 04:08 PM
Playing with stuff today and thought I would pass some pictures along. Found out there are TWO slightly different 915 transmission flanges. The one on my 914 trans is the early without a flange. The second has a lip like the 944 axle. The 74- up 100mm stub axle is shown and the gasket goes to the inside. There is an early 100mm NLA heavy duty boot and the cheap 944 replacement version. Cleaned and gun barrel finished 2nd style trans flange. Have a chrome moly axle set for full floating axles. Using 944 CV joints.
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Dr Evil
post Apr 13 2023, 05:03 PM
Send me your transmission!
More than two types of output flanges, and that’s just the coarse splined ones. The number cast I to them can be the same for all with the same dia head. Then there are variations on shaft dia (34 or 35mm), length (LSD, non LSD) and the face width where the gaskets rests from the case. I have a few of these iterations and my last 915 customer bought the wrong flanges (34mm) so they were wiggly in the bore and not useable with his diff. The parts were cast with the same pn and then machined for what they were needed on that casting.
- Lo-Fi Version Time is now: 9th December 2025 - 12:09 PM
