Suspension setup recommendations daily driver / rough roads |
skota23 |
Apr 13 2023, 08:12 PM
Newbie Group: Members Posts: 35 Joined: 28-November 22 From: Madison, WI Member No.: 26,993 Region Association: Upper MidWest |
Hi folks,
Now that I have my car running well it’s time to start making it handle how I want and would like some advice. It’s a 74 2.0 Here’s what it has now, Front sway bar (factory) Stock torsion bars Struts, not sure but the car came with a used set of konis (rebuilding konis an option?) Rear Kyb’s these I’m thinking about replacing with bilstiens with adjustable spring perches 140# springs, I’m thinking 100# to replace them Tires are old 205/60/15’s that I’m planning on replacing with 185/70 vredestein I’d like to raise the car up a bit for ground clearance and comfort but not compromise handling too much. I’d appreciate anyone’s thoughts. Thank you, Steve Attached thumbnail(s) |
Garland |
Apr 14 2023, 03:11 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Now that I have my car running well it’s time to start making it handle how I want it to 74 2.0 Replying to Suspension setup recommendations daily driver / rough roads Front sway bar (factory) Stock torsion bars springs, I’m thinking 100# Tires 185/70 vredestein I’d like to raise the car up a bit for ground clearance and comfort but not compromise handling too much. You would be Surprised at how well, the car handles at its proper alignment, height & geometry, and factory dampening. Boge shocks, factory rated springs. I’ve found for street driving they’re very good. Maybe A bit short life in the rears. With only slightly larger tires. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:00 AM |
