> Wheel fitment
L-Jet914
post Apr 15 2023, 10:53 PM
I recently installed these wheels along with the stud kit to use the wheels. Drove it around to settle the suspension back down. I've read in older forum posts regarding clearance between driver and passenger side rear and vice versa. My passenger side rear had more clearance between the fender and tire, the driver side rear maybe has 1.5-2.0mm of clearance. I know I need to do an alignment on the car, but I think my factory coil springs have given up the ghost. So I ordered a set from 914Rubber. Do you think the springs may fix my issue or alignment? Tires on the Minilites are 205/55R15 currently.
Dave_Darling
post Apr 16 2023, 11:36 PM
914 Idiot
2mm is not much clearance; you may get a rub while driving around.
If the tight spot is on the top of the tire (which is common), then some more negative camber can help. Going too far with that can accelerate your tire wear, but that can be evened out by flipping the tires on the rim periodically.
--DD
- Lo-Fi Version Time is now: 1st August 2025 - 05:25 PM
