| Puebloswatcop |
Apr 20 2023, 05:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,701 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Has anyone tried the Brass Shift Rod Bushings available from Pelican? Are they worth the money or are they snake oil?
| dr914@autoatlanta.com |
Apr 21 2023, 01:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
it has been our experience that they wear out the linkage and are noisy
Puebloswatcop Shift Rod Bushings Apr 20 2023, 05:48 PM
NARP74 Got a link so I can see which ones? Apr 20 2023, 05:51 PM
windforfun I went with a new nylon bushing for the firewall. ... Apr 20 2023, 05:51 PM
NARP74
I went with a new nylon bushing for the firewall.... Apr 20 2023, 05:56 PM
windforfun
I went with a new nylon bushing for the firewall... Apr 20 2023, 06:22 PM
windforfun
I went with a new nylon bushing for the firewall... Apr 20 2023, 06:23 PM
Dlee6205 I use them on almost every car in the shop. I fe... Apr 20 2023, 06:12 PM
rfinegan Do all three here if you are taking it apart...you... Apr 21 2023, 08:15 AM
914Sixer Cheaper on Ebay Apr 20 2023, 08:57 PM
rhodyguy If you heat the FW bushing up in HOT water to soft... Apr 20 2023, 08:58 PM
porschetub
If you heat the FW bushing up in HOT water to sof... Apr 21 2023, 01:21 PM
914werke it has been our experience that they wear out the... Apr 21 2023, 02:27 PM
Root_Werks I have nylon or whatever it's made of at the f... Apr 21 2023, 02:50 PM
914Sixer Here is mine with late 911 reinforced shifter coup... Apr 22 2023, 12:09 PM
Puebloswatcop Thanks for Y'alls input. I do have the poly b... Apr 22 2023, 07:43 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:25 PM |
