> 2,0 starting problems.
Lars OLesen
post Apr 22 2023, 01:13 PM
Hello you all
Thanks for a great and informative forum (IMG:style_emoticons/default/smile.gif)
Sorry for my poor american, I´m danish.
I have a 74 2,0 which can not start. Prior to this it only startet on 2 cylinders and after a 5 min. warm up it ran on all 4 , but often with a lot of hick ups.
I pulled the distributor, cleaned the trigger points which look fine, fixed the ignition advancing which was stuck. cleaned everything and lubed the moving parts. I found out that one of the connections in the 3 legged connection for the trigger points was not pushed all the way in, hope this will cure the starting on 2 cyl. and hick up problem.
But now it will not start. I´ve checked everything multible times and found out it is lack of fuel to the injectors. Only the start up injector works.
Any ideas about what I fucked up?
Any help will be appreciated (IMG:style_emoticons/default/smile.gif)
Regards Lars
- Lo-Fi Version Time is now: 7th November 2026 - 05:45 AM
