Comression ratio advice, 6 cylinder motor build |
team914 |
Apr 22 2023, 04:06 PM
Newbie Group: Members Posts: 3 Joined: 5-April 20 From: Ireland Member No.: 24,102 Region Association: Europe |
Hi,
I am planning to build a 6 cylinder street motor for my 914/6 factory replica. My original 84mm barrels were worn, so I elected to machine the barrels to 84.5mm and have bought a set of 84.5mm Wossner pistons. With a 70.4mm crank, the compression ratio is stated at 10.11:1 with the pistons out of the box. I intend on using Weber carbs, E cams and an E distributor/123 Distributor. My machine shop engineer has recommended reducing the compression ratio from the 10.11:1 to a more suitable figure. The petrol quality in Ireland is poor, typically 95 octane, and we now have a compulsory addition of 10% Ethanol added (E10)! Any advice greatly appreciated |
mepstein |
Apr 22 2023, 04:15 PM
914-6 GT in waiting Group: Members Posts: 19,314 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You want to measure the actual compression ratio and not just count on what’s stated in the tech sheet. Especially if you are making changers, you want a known baseline, not just theoretical.
(IMG:style_emoticons/default/welcome.png) |
nditiz1 |
Apr 22 2023, 05:55 PM
Senior Member Group: Members Posts: 1,191 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
You want to measure the actual compression ratio and not just count on what’s stated in the tech sheet. Especially if you are making changers, you want a known baseline, not just theoretical. (IMG:style_emoticons/default/welcome.png) Agree with this. With my 3.2, you would think 9.5:1 with JE pistons being 9.5:1 ,but when measured CR is actually 9.4:1. |
Lo-Fi Version | Time is now: 9th June 2024 - 09:49 AM |
