| Lars OLesen |
Apr 22 2023, 01:13 PM
Newbie ![]() Group: Members Posts: 5 Joined: 13-December 19 From: Denamrk Member No.: 23,738 Region Association: None |
Hello you all
Thanks for a great and informative forum (IMG:style_emoticons/default/smile.gif) Sorry for my poor american, I´m danish. I have a 74 2,0 which can not start. Prior to this it only startet on 2 cylinders and after a 5 min. warm up it ran on all 4 , but often with a lot of hick ups. I pulled the distributor, cleaned the trigger points which look fine, fixed the ignition advancing which was stuck. cleaned everything and lubed the moving parts. I found out that one of the connections in the 3 legged connection for the trigger points was not pushed all the way in, hope this will cure the starting on 2 cyl. and hick up problem. But now it will not start. I´ve checked everything multible times and found out it is lack of fuel to the injectors. Only the start up injector works. Any ideas about what I fucked up? Any help will be appreciated (IMG:style_emoticons/default/smile.gif) Regards Lars |
| emerygt350 |
Apr 23 2023, 05:41 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,812 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Sounds like that maybe be it. Control of the injector banks is from the trigger points, of course, and duration is controlled by the ECU with input from the mps and cht. No chance you disconnected the mps? I doubt that would do it but you never know.
You sure the plug is back on the trigger points correctly? Also make sure the distributor is fully seated. I hate pulling the injectors but it is the quickest way to verify. I mucked with my original distributor for a few months, got it working pretty good, pulled it, put it safely on a shelf and installed the 123. Well worth it and no more wear and tear on the original. |
Lars OLesen 2,0 starting problems. Apr 22 2023, 01:13 PM
emerygt350 Hello Lars and welcome to 914world!
It sound... Apr 22 2023, 01:28 PM
r_towle An easy test is to pull all four injectors out of ... Apr 22 2023, 01:59 PM
r_towle And,
New fuel lines, fuel filter, verify no leaks ... Apr 22 2023, 02:01 PM
Lars OLesen
And,
New fuel lines, fuel filter, verify no leaks... Apr 23 2023, 01:29 AM
930cabman :wttc: I am more of a carb guy so I won't b... Apr 23 2023, 05:07 AM
Lars OLesen Thanks for all your input..
Problem solved for no... Apr 23 2023, 10:42 AM
emerygt350 Check your mps to see if it holds vacuum.
1400 so... Apr 23 2023, 01:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th November 2026 - 05:45 AM |
