| VolksSled |
May 3 2023, 08:48 AM
Newbie ![]() Group: Members Posts: 28 Joined: 3-May 23 From: California Member No.: 27,331 Region Association: Southern California |
(IMG:style_emoticons/default/poke.gif)
Hi New member here with a new to me bad ass 914 ( big /4) with webbers I just bought the tangerine throttle linkage To replace the home made linkage that was on there and did work well for a while I know that if it’s from tangerine it should be quality But I also ordered this induction from Germany Anyone have this ? (IMG:style_emoticons/default/beer3.gif) And will it clear the tangerine throttle linkage ??? https://www.thoro-tec.de/en/p/air-intake-sy...14-bulli-beetle ( & before I forget ) shout out to the cheap sob (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/wub.gif) Who I’m sure would be turning in his grave knowing I spent 999 euros on a intake ������ |
| VaccaRabite |
May 3 2023, 12:43 PM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
I just don't understand how that is a $999 euro part, and it blocks access to the oil filler. Also one cone filter has less dust catching surface then 2 carb mounted air cleaners - meaning that you are getting less airflow especially when the filter starts collecting dirt.
The big reason folks try to tie the throttle bodies together is to abate intake noise, but the cone filter pointed at the cabin is going to negate that too. So, aside from it looking kinda cool - what does it get you? Zach |
| NARP74 |
May 3 2023, 01:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I just don't understand how that is a $999 euro part, and it blocks access to the oil filler. Also one cone filter has less dust catching surface then 2 carb mounted air cleaners - meaning that you are getting less airflow especially when the filter starts collecting dirt. The big reason folks try to tie the throttle bodies together is to abate intake noise, but the cone filter pointed at the cabin is going to negate that too. So, aside from it looking kinda cool - what does it get you? Zach This |
Nazisled Anyone running this intake ? May 3 2023, 08:48 AM
Nazisled Uninstalled May 3 2023, 08:49 AM
Nazisled 914 May 3 2023, 08:55 AM
r_towle 1) change your name, its stupid and its 2023
2) st... May 3 2023, 09:03 AM
Nazisled
2) s... May 3 2023, 09:13 AM
Nazisled
2) s... May 3 2023, 09:14 AM
rhodyguy Note the center pull linkage. Perhaps that’s wha... May 3 2023, 09:18 AM
BillJ So assuming you are just new and all...
I have no... May 3 2023, 09:22 AM
rhodyguy Most CASoB 914 owners don’t like dropping over 1... May 3 2023, 09:35 AM
Nazisled
Most CASoB 914 owners don’t like dropping over ... May 3 2023, 09:47 AM
Nazisled
Most CASoB 914 owners don’t like dropping over... May 3 2023, 09:48 AM
JamesM
[quote name='Nazisled' post='3075498' date='May 3... May 3 2023, 10:44 AM
VolksSled
[quote name='Nazisled' post='3075499' date='May 3... May 3 2023, 12:00 PM
JamesM
I saw these before I pulled the trigger
I’m ... May 3 2023, 12:38 PM
NARP74 I don't see how this intake can be any better ... May 3 2023, 09:53 AM
sportlicherFahrer The intake system appears to be well above where t... May 3 2023, 10:49 AM
rhodyguy I never found the carb sound obnoxious. Goes with ... May 3 2023, 02:47 PM
brubou why is his name offensive? May 3 2023, 02:57 PM
rjames
Admins changed it, s... May 3 2023, 03:08 PM
Dave_Darling
Look carefully at th... May 6 2023, 11:09 PM
NARP74 With this air intake near the cooling fan intake, ... May 5 2023, 09:14 AM
VolksSled I guess we’re not gonna find out
Supplier said ... May 5 2023, 09:40 AM
rhodyguy Buy bigger containers of the cleaner and oil for t... May 5 2023, 12:31 PM
sechszylinder I guess that this air cleaner ist somewhat useless... May 7 2023, 02:29 AM
VolksSled
I guess that this air cleaner ist somewhat useles... May 9 2023, 10:42 AM
bbrock If you are truly a CSOB and wan a quiet intake, yo... May 7 2023, 07:37 PM
VaccaRabite
If you are truly a CSOB and wan a quiet intake, y... May 8 2023, 10:23 AM
bbrock
This is brilliant. This is what we need.
I que... May 9 2023, 03:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:26 PM |
