> 718 turbo 4 in a 914?, Anyone tried yet?
r_towle
post May 4 2023, 07:34 AM
Custom Member
Mid or rear engine swaps out there?
Rich
r_towle
post May 4 2023, 11:15 AM
Custom Member
suppose someone would want to use the 2.0 liter NA motor in a rear engine application.
What transmission would work?
It would be best to go to a smaller, older, air-cooled tranny (901 or 915)
I suppose a larger tranny could be done...its just metal to cut out of the way (IMG:style_emoticons/default/smile.gif)
Rich
ClayPerrine
post May 4 2023, 11:23 AM
QUOTE(r_towle @ May 4 2023, 12:15 PM) *
Rich
The transmission is not the problem. I already worked that one out. It just takes a custom transmission mount.
The problem with the NA 718 motor is the width. I don't think it will fit between the inboard suspension console ears of a 914 chassis. I know a Boxster/Cayman six won't fit because it is too wide. I suspect the 718 motor is the same width, just shy two cylinders.
r_towle   718 turbo 4 in a 914?   May 4 2023, 07:34 AM
ClayPerrine   Mid or rear engine swaps out there? Rich You ...   May 4 2023, 07:49 AM
burton73   Mid or rear engine swaps out there? Rich You...   May 4 2023, 08:18 AM
ClayPerrine   [quote name='ClayPerrine' post='3075726' date='Ma...   May 4 2023, 11:10 AM
r_towle   Mid or rear engine swaps out there? Rich You...   May 4 2023, 05:05 PM
tygaboy   This swap is a possibility for a build I have in m...   May 4 2023, 08:29 AM
r_towle   suppose someone would want to use the 2.0 liter NA...   May 4 2023, 11:15 AM
ClayPerrine   suppose someone would want to use the 2.0 liter N...   May 4 2023, 11:23 AM
technicalninja   I was under the impression that a Cayman S six cyl...   May 4 2023, 12:20 PM
yellowporky   There was a guy in Australia I believe that put th...   May 4 2023, 12:27 PM
ClayPerrine   I am going to coil on plug for the 4.0L engine, an...   May 4 2023, 02:35 PM
Olympic 914   Or you could just buy a 718 Turbo 4 Boxster/Cayman...   May 5 2023, 06:31 AM
horizontally-opposed   Or you could just buy a 718 Turbo 4 Boxster/Cayma...   May 5 2023, 08:48 AM
Spoke   Or you could just buy a 718 Turbo 4 Boxster/Cayma...   May 8 2023, 11:19 AM
horizontally-opposed   Upside, it's a Porsche flat four rather than a...   May 5 2023, 08:31 AM
aturboman   Turbo 914-6 in progress....   May 5 2023, 11:03 AM
DRPHIL914   Turbo 914-6 in progress.... @[url=http://www...   May 5 2023, 11:45 AM
burton73   Wow! loving this. Bob B   May 5 2023, 11:31 AM
r_towle   What is the difference between a 3.0 liter SC moto...   May 5 2023, 12:04 PM
horizontally-opposed   @horizontalky-opposed 4-cam, variable valve, with...   May 5 2023, 01:36 PM
aturboman   Crankcase and bottom end is different but you can ...   May 5 2023, 01:20 PM
r_towle   Does anyone have access to a 718/4 engine? Need me...   May 5 2023, 01:44 PM
Thunderchief   I was literally shopping for 718 engines on ebay a...   May 6 2023, 11:11 PM
Rod   https://youtu.be/bIZqSNkkteE?si=N3ijOAYktmg4u8mM   Aug 28 2024, 12:31 AM
- Lo-Fi Version Time is now: 5th March 2026 - 06:11 AM
