Oval fuel line grommet - front of tunnel, Oval fuel line grommet - front of tunnel |
mgarrison |
May 4 2023, 08:25 PM
Member Group: Members Posts: 351 Joined: 14-February 20 From: Chandler, AZ Member No.: 23,922 Region Association: Southwest Region |
Is there a source from the large, oval grommet for the fuel lines at the front of the tunnel where the lines protrude into the area under the fuel tank? So far I have been unable to find a vendor that sells them.
I swiped this diagram from 914Rubber - the piece I'm referring to I've circled in red... |
914werke |
May 4 2023, 10:11 PM
"I got blisters on me fingers" Group: Members Posts: 10,116 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
mgarrison |
May 5 2023, 07:29 AM
Thank you Sir! (IMG:style_emoticons/default/pray.gif) The early/late is so dang applicable; my 914 is a 1974, assembled 11/73 and it turns out the tank and vapor system are the early version (got the wrong fuel tank despite having to confirm the year) (IMG:style_emoticons/default/wacko.gif) |
wonkipop |
May 5 2023, 08:05 AM
Advanced Member Group: Members Posts: 4,367 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Thank you Sir! (IMG:style_emoticons/default/pray.gif) The early/late is so dang applicable; my 914 is a 1974, assembled 11/73 and it turns out the tank and vapor system are the early version (got the wrong fuel tank despite having to confirm the year) (IMG:style_emoticons/default/wacko.gif) the changeover to the engine bay charcoal canister as far as we ascertained from L jet research a year or so back is around either side of the weekend 17/18 Nov 1973. be good to add your vin build date to the data we have to see how it checks with that. |
mgarrison |
May 5 2023, 10:12 AM
Thank you Sir! (IMG:style_emoticons/default/pray.gif) The early/late is so dang applicable; my 914 is a 1974, assembled 11/73 and it turns out the tank and vapor system are the early version (got the wrong fuel tank despite having to confirm the year) (IMG:style_emoticons/default/wacko.gif) the changeover to the engine bay charcoal canister as far as we ascertained from L jet research a year or so back is around either side of the weekend 17/18 Nov 1973. be good to add your vin build date to the data we have to see how it checks with that. Here's what info I have on my car: VIN: 4742908715 Chassis Number: 4649581 Build Date: 11/73 I am unsure if my 914 was a 1.7 or 2.0 - I haven't found any emblem, documentation, etc. that would indicate. It had the steel expansion tank on top of the fuel tank. No charcoal canister that I've seen in the parts that came with the car - many of the parts were removed by a previous owner for a planned electric conversion. |
wonkipop |
May 5 2023, 03:41 PM
Thank you Sir! (IMG:style_emoticons/default/pray.gif) The early/late is so dang applicable; my 914 is a 1974, assembled 11/73 and it turns out the tank and vapor system are the early version (got the wrong fuel tank despite having to confirm the year) (IMG:style_emoticons/default/wacko.gif) the changeover to the engine bay charcoal canister as far as we ascertained from L jet research a year or so back is around either side of the weekend 17/18 Nov 1973. be good to add your vin build date to the data we have to see how it checks with that. Here's what info I have on my car: VIN: 4742908715 Chassis Number: 4649581 Build Date: 11/73 I am unsure if my 914 was a 1.7 or 2.0 - I haven't found any emblem, documentation, etc. that would indicate. It had the steel expansion tank on top of the fuel tank. No charcoal canister that I've seen in the parts that came with the car - many of the parts were removed by a previous owner for a planned electric conversion. thanks for the info. what i can tell you is its very likely that it is a 74MY 1.8 L-jetronic and a very early one. we ended up with reasonably extensive data, not enough to pin down precise dates for progressive changes of the 74MY cars but close enough to pinpoint the week changes happened or in some cases within 3 days of changes. for 74 MY it would appear that 2.0 L cars were produced exclusively from August until very late Oct 1973. then 1.8L production commenced from later Oct/early Nov 1973 until sometime late Jan/part way into Feb 1974 exclusively. after late Jan/early Feb 1974 the production of both 2.0L and 1.8 L cars is more varied and mixed. as far as we can determine the 74 MY was unusual in that respect. the reason very likely was a delay in entering production of the L jetronic injection system for the 1.8 cars. the first batch of 2.0L cars in the first 3 months of production and the first 3 weeks of production of the 1.8s all have the earlier fuel tank with the charcoal canister mounted in the front trunk. after that all the 1.8 and 2.0 74 cars have the canister in the engine bay and they run a small diameter fume (vapor) line through the central tunnel to the can along with the fuel lines. the steel expansion tank did not change at the same time as the charcoal canister mount and location. the expansion tank is changed to a plastic part and the design is revised much later in may 1974 and is on the last 2-3 months of production. the plastic tank is part of the redesign to get the fuel cap restricter on for unleaded fuel only in prep for the exhaust cat on 75 (california to start with) models on. folks talk of a just a late and early tank. but in fact there is a variant in between and its on the 74 cars from late nov 73 to may 74. its a tank without the slot and bracket for a clip for the charcoal can but it also has a metal expansion tank. this variant wasn't really noted down until more recently when we did the L jet research. yours is pretty clear cut, i would expect it to be 99% the early fuel tank on all cars pre 74MY. @914werke makes an interesting point about fuel line sizes. might have to look into that further. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) another rabbit hole. i noticed the fuel pump that i took off mine and i think (99%) it was original was a 009 with three equal ports. however there was a difference in the plastic lines running through the central tunnel. the feed line was still slightly bigger. anyway, nothing to do with early fuel tanks. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 11:20 AM |
