Clutch pedal travel excessive |
peteinjp |
Apr 10 2023, 06:53 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not wanting to put any undue pressure on the TOB I pulled the cable end as far forward as i could while pushing the clutch lever as far back and adjusted the cable with no free play. Tube is good, cable, pressure plate, flywheel etc all have about 30,000kms. Pedal stop is low and yet I have to push the pedal all the way to the floor to keep from grinding in 1st and reverse. I can not pull the pedal back at all as described in the factory manual. It works but barely- the travel is too far even with the cable adjusted with slight pressure on the shift fork lever.
It seems to me there should always be just the slightest play in the cable- no?? Any thoughts? Pete |
peteinjp |
May 7 2023, 11:23 PM
Thanks for digging that up! Big help and interesting info.
The engine put out over 190ft-lb on the dyno so I'm just over the spec for that plate...... I wrote to a couple of places including Patrick Motor Sports but did not hear back..... Pete Also have an email in to Rothsport as they built the car. |
Lo-Fi Version | Time is now: 7th June 2024 - 08:37 AM |
