> Anyone running this intake ?, & Will it work with tangerine throttle linkage ?
VolksSled
post May 3 2023, 08:48 AM
(IMG:style_emoticons/default/poke.gif)
Hi
New member here with a new to me bad ass
914 ( big /4) with webbers
I just bought the tangerine throttle linkage
To replace the home made linkage that was on there and did work well for a while
I know that if it’s from tangerine it should be quality
But I also ordered this induction from Germany
Anyone have this ? (IMG:style_emoticons/default/beer3.gif)
And will it clear the tangerine throttle linkage ???
https://www.thoro-tec.de/en/p/air-intake-sy...14-bulli-beetle
( & before I forget ) shout out to the cheap sob (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/wub.gif)
Who I’m sure would be turning in his grave knowing I spent 999 euros on a intake ������
bbrock
post May 7 2023, 07:37 PM
If you are truly a CSOB and wan a quiet intake, you can make your own (IMG:style_emoticons/default/biggrin.gif)
https://www.youtube.com/watch?v=Xm-LOk_IBpg
http://www.914world.com/bbs2/index.php?showtopic=352004
http://www.914world.com/bbs2/index.php?s=&...t&p=2868946
VaccaRabite
post May 8 2023, 10:23 AM
En Garde!
QUOTE(bbrock @ May 7 2023, 09:37 PM) *
This is brilliant. This is what we need.
I question if the stock horn has enough opening to feed it, but thats a fixable issue if its an issue at all.
Zach
bbrock
post May 9 2023, 03:11 PM
QUOTE(VaccaRabite @ May 8 2023, 09:23 AM) *
Zach
My engine is stock other than the mild carb cam and intake seems to be more than adequate, but like you said, could easily be configured any way you like. I was told that someone measured air temps around the engine bay several years ago and if I'd have just run the horn straight out to the left side, it would probably suck colder air than up by the cooling fan that required the fancy bend.
I keep thinking that a person could 3D print the housings, intakes and whatever horn config is preferred and have a plug and play retrofit kit for old bus air boxes. The mounting bracket would also need to be manufactured.
The configuration shown in the video did wind up interfering with rain tray so I wound up having to chop the bracket down and mod the intakes a little to make it fit. Still looks and works the same, just sits a couple inches lower in the bay.
Nazisled   Anyone running this intake ?   May 3 2023, 08:48 AM
Nazisled   Uninstalled   May 3 2023, 08:49 AM
Nazisled   914   May 3 2023, 08:55 AM
r_towle   1) change your name, its stupid and its 2023 2) st...   May 3 2023, 09:03 AM
Nazisled   1) change your name, its stupid and its 2023 2) s...   May 3 2023, 09:13 AM
Nazisled   1) change your name, its stupid and its 2023 2) s...   May 3 2023, 09:14 AM
rhodyguy   Note the center pull linkage. Perhaps that’s wha...   May 3 2023, 09:18 AM
BillJ   So assuming you are just new and all... I have no...   May 3 2023, 09:22 AM
rhodyguy   Most CASoB 914 owners don’t like dropping over 1...   May 3 2023, 09:35 AM
Nazisled   Most CASoB 914 owners don’t like dropping over ...   May 3 2023, 09:47 AM
Nazisled   Most CASoB 914 owners don’t like dropping over...   May 3 2023, 09:48 AM
JamesM   [quote name='Nazisled' post='3075498' date='May 3...   May 3 2023, 10:44 AM
VolksSled   [quote name='Nazisled' post='3075499' date='May 3...   May 3 2023, 12:00 PM
JamesM   I saw these before I pulled the trigger I’m ...   May 3 2023, 12:38 PM
NARP74   I don't see how this intake can be any better ...   May 3 2023, 09:53 AM
sportlicherFahrer   The intake system appears to be well above where t...   May 3 2023, 10:49 AM
VaccaRabite   I just don't understand how that is a $99...   May 3 2023, 12:43 PM
NARP74   I just don't understand how that is a $9...   May 3 2023, 01:40 PM
rhodyguy   I never found the carb sound obnoxious. Goes with ...   May 3 2023, 02:47 PM
brubou   why is his name offensive?   May 3 2023, 02:57 PM
rjames   why is his name offensive? Admins changed it, s...   May 3 2023, 03:08 PM
Dave_Darling   why is his name offensive? Look carefully at th...   May 6 2023, 11:09 PM
NARP74   With this air intake near the cooling fan intake, ...   May 5 2023, 09:14 AM
VolksSled   I guess we’re not gonna find out Supplier said ...   May 5 2023, 09:40 AM
rhodyguy   Buy bigger containers of the cleaner and oil for t...   May 5 2023, 12:31 PM
sechszylinder   I guess that this air cleaner ist somewhat useless...   May 7 2023, 02:29 AM
VolksSled   I guess that this air cleaner ist somewhat useles...   May 9 2023, 10:42 AM
bbrock   If you are truly a CSOB and wan a quiet intake, yo...   May 7 2023, 07:37 PM
VaccaRabite   If you are truly a CSOB and wan a quiet intake, y...   May 8 2023, 10:23 AM
bbrock   This is brilliant. This is what we need. I que...   May 9 2023, 03:11 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:05 AM
