Clutch pedal travel excessive |
peteinjp |
Apr 10 2023, 06:53 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not wanting to put any undue pressure on the TOB I pulled the cable end as far forward as i could while pushing the clutch lever as far back and adjusted the cable with no free play. Tube is good, cable, pressure plate, flywheel etc all have about 30,000kms. Pedal stop is low and yet I have to push the pedal all the way to the floor to keep from grinding in 1st and reverse. I can not pull the pedal back at all as described in the factory manual. It works but barely- the travel is too far even with the cable adjusted with slight pressure on the shift fork lever.
It seems to me there should always be just the slightest play in the cable- no?? Any thoughts? Pete |
914werke |
May 12 2023, 11:23 AM
"I got blisters on me fingers" Group: Members Posts: 10,138 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
assume youve looked at this but thought its worth checking as I've seen this on multiple boxes where the stamped steel pivot fork is no longer ... true.
Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 05:09 PM |
