> Door handle opener, Need a pointer here....
jim_hoyland
post Jun 13 2018, 10:38 AM
Get that VIN ?
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok
There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it.
Anyone else had this problem ?
TheCabinetmaker
post May 14 2023, 08:23 AM
I drive my car everyday
There's nothing wrong with the handles, or the adjustments. The latch mechanism inside the door is dirty, and the 50 years old grease is like modeling clay. Remove it and give it a thorough cleaning and relube with white lithium grease. Dirty latches are the #1 cause of broken door handles
jim_hoyland   Door handle opener   Jun 13 2018, 10:38 AM
Elliot Cannon   I have always considered the 914 door handles to b...   Jun 13 2018, 10:48 AM
914_teener   Jim, The handle looks to be very dirty. It needs...   Jun 13 2018, 10:51 AM
rdauenhauer   its been rebuilt. Notice that one side is a philip...   Jun 13 2018, 10:55 AM
jdamiano   Your door looks like it needs to be adjusted. Soun...   Jun 13 2018, 10:56 AM
SirAndy   Your door looks like it needs to be adjusted. Soun...   Jun 13 2018, 11:26 AM
Tom_T   Your door looks like it needs to be adjusted. Sou...   Jun 13 2018, 12:15 PM
bbrock   Your door looks like it needs to be adjusted. Sou...   Jun 13 2018, 01:30 PM
jim_hoyland   Thanks for those tips: I’ll clean the handle any...   Jun 13 2018, 10:59 AM
BENBRO02   Thanks for those tips: I’ll clean the handle an...   Jun 13 2018, 11:15 AM
Travis Neff   The door gap sure looks tight. Also, the door cou...   Jun 13 2018, 11:31 AM
The Cabinetmaker   Not the handle. The latch on the door is dirty   Jun 13 2018, 11:33 AM
jim_hoyland   Loosened and reset the catch on the door jamb, wor...   Jun 13 2018, 11:52 AM
bbrock   There is good info in the factory manual on adjust...   Jun 13 2018, 01:28 PM
jim_hoyland   Thanks Tom; Is there a trick to loosening the doo...   Jun 13 2018, 01:35 PM
SirAndy   Thanks Tom; Is there a trick to loosening the do...   Jun 13 2018, 02:18 PM
jim_hoyland   Thanks Tom; Is there a trick to loosening the d...   Jun 13 2018, 03:33 PM
Medtner3   Thanks Tom; Is there a trick to loosening the d...   Aug 20 2023, 11:34 AM
Travis Neff   Loosen the 6 bolts at the front hinges and move th...   Jun 13 2018, 01:40 PM
Larmo63   The inside of the door latches work SO much better...   Jun 13 2018, 02:02 PM
mgphoto   The inside of the door latches work SO much bette...   Jun 13 2018, 02:37 PM
rhodyguy   How hard is it to turn the latching piece by hand?   Jun 13 2018, 02:24 PM
SirAndy   Where is the rubber block that should be on the l...   Jun 13 2018, 02:30 PM
rhodyguy   Right. You captured it while I was editing. Senior...   Jun 13 2018, 02:34 PM
cary   The latch portion in the door needs a DEEP clean. ...   Jun 13 2018, 07:08 PM
Root_Werks   The latch portion in the door needs a DEEP clean....   May 15 2023, 11:45 AM
914sgofast2   I had a similar problem with both of my doors. E...   Jun 13 2018, 08:11 PM
Richncherie   72 914 cannot unlock the driver side door with key...   Jan 16 2023, 09:32 PM
jim_hoyland   Thanks for reminding me ofmy own thread !   May 13 2023, 06:11 AM
TheCabinetmaker   There's nothing wrong with the handles, or the...   May 14 2023, 08:23 AM
jim_hoyland   A trick I used when re-installing the latch at the...   May 17 2023, 08:39 AM
dr914@autoatlanta.com   remove the catching mechanism and clean it thoroug...   May 17 2023, 08:44 AM
bbrock   Well, I've been fighting the same problem on m...   May 17 2023, 04:47 PM
- Lo-Fi Version Time is now: 16th November 2026 - 06:07 PM
