> Door handle opener, Need a pointer here....
jim_hoyland
post Jun 13 2018, 10:38 AM
Get that VIN ?
I’m helping SB914 get his passenger door handle to work. The interior pull works fine; the exterior pull will not work unless I push in on the door first.
Took the handle out; it’s ok
There’s not a lot of adjustment for the mechanism and i’m Trying to not remove it.
Anyone else had this problem ?
bbrock
post May 17 2023, 04:47 PM
Well, I've been fighting the same problem on my passenger door and it is not a dirty mechanism problem. The door handle was cleaned meticulously during full resto and lubed with Tri-flow. The catch on the door pillar was stripped and re-plated. The driver's door works like butter but I have yet to adjust the passenger side where I don't have to push in or the door before pulling the handle to release. Works fine opening from the interior door release though. Sorry I don't have any tips to share. Just some company being in the same boat. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland   Door handle opener   Jun 13 2018, 10:38 AM
Elliot Cannon   I have always considered the 914 door handles to b...   Jun 13 2018, 10:48 AM
914_teener   Jim, The handle looks to be very dirty. It needs...   Jun 13 2018, 10:51 AM
rdauenhauer   its been rebuilt. Notice that one side is a philip...   Jun 13 2018, 10:55 AM
jdamiano   Your door looks like it needs to be adjusted. Soun...   Jun 13 2018, 10:56 AM
SirAndy   Your door looks like it needs to be adjusted. Soun...   Jun 13 2018, 11:26 AM
Tom_T   Your door looks like it needs to be adjusted. Sou...   Jun 13 2018, 12:15 PM
bbrock   Your door looks like it needs to be adjusted. Sou...   Jun 13 2018, 01:30 PM
jim_hoyland   Thanks for those tips: I’ll clean the handle any...   Jun 13 2018, 10:59 AM
BENBRO02   Thanks for those tips: I’ll clean the handle an...   Jun 13 2018, 11:15 AM
Travis Neff   The door gap sure looks tight. Also, the door cou...   Jun 13 2018, 11:31 AM
The Cabinetmaker   Not the handle. The latch on the door is dirty   Jun 13 2018, 11:33 AM
jim_hoyland   Loosened and reset the catch on the door jamb, wor...   Jun 13 2018, 11:52 AM
bbrock   There is good info in the factory manual on adjust...   Jun 13 2018, 01:28 PM
jim_hoyland   Thanks Tom; Is there a trick to loosening the doo...   Jun 13 2018, 01:35 PM
SirAndy   Thanks Tom; Is there a trick to loosening the do...   Jun 13 2018, 02:18 PM
jim_hoyland   Thanks Tom; Is there a trick to loosening the d...   Jun 13 2018, 03:33 PM
Medtner3   Thanks Tom; Is there a trick to loosening the d...   Aug 20 2023, 11:34 AM
Travis Neff   Loosen the 6 bolts at the front hinges and move th...   Jun 13 2018, 01:40 PM
Larmo63   The inside of the door latches work SO much better...   Jun 13 2018, 02:02 PM
mgphoto   The inside of the door latches work SO much bette...   Jun 13 2018, 02:37 PM
rhodyguy   How hard is it to turn the latching piece by hand?   Jun 13 2018, 02:24 PM
SirAndy   Where is the rubber block that should be on the l...   Jun 13 2018, 02:30 PM
rhodyguy   Right. You captured it while I was editing. Senior...   Jun 13 2018, 02:34 PM
cary   The latch portion in the door needs a DEEP clean. ...   Jun 13 2018, 07:08 PM
Root_Werks   The latch portion in the door needs a DEEP clean....   May 15 2023, 11:45 AM
914sgofast2   I had a similar problem with both of my doors. E...   Jun 13 2018, 08:11 PM
Richncherie   72 914 cannot unlock the driver side door with key...   Jan 16 2023, 09:32 PM
jim_hoyland   Thanks for reminding me ofmy own thread !   May 13 2023, 06:11 AM
TheCabinetmaker   There's nothing wrong with the handles, or the...   May 14 2023, 08:23 AM
jim_hoyland   A trick I used when re-installing the latch at the...   May 17 2023, 08:39 AM
dr914@autoatlanta.com   remove the catching mechanism and clean it thoroug...   May 17 2023, 08:44 AM
bbrock   Well, I've been fighting the same problem on m...   May 17 2023, 04:47 PM
- Lo-Fi Version Time is now: 16th November 2026 - 06:07 PM
