Help: tangerine racing ss fuel line install |
shredtherad |
May 18 2023, 08:00 AM
Member Group: Members Posts: 86 Joined: 17-May 22 From: Longmont, Colorado Member No.: 26,559 Region Association: Rocky Mountains |
I got the tank out, removed the old lines, got the fuel lines through the tunnel but I am stuck on how the engine bay lines work.
Anyone have any photos of how they worked that one? Or what the layout looks like? Also, anyone have a schematic on how the layout looks for the fuel pump relocation to the front under the car but the steering rack? I must suck at searching because I was unable to find what I was looking for... thanks all! |
sportlicherFahrer |
May 18 2023, 10:21 AM
Nothing to see here. Group: Members Posts: 1,088 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
If the pump is in front, the feed line (rubber) goes up the passenger long, along the back trunk wall, then connects to the fuel pressure regulator. Off the regulator feeds the driver side injectors, then from there to the passenger side injectors, then back to the return line to the tank. I guess it’s up to you, but the regulator is first, then injectors Got that backwards. Pressure goes from the tunnel to the #3/#4 rail, across the top of the engine to the #1/#2 rail, then to the regulator. Ljet has the CSV in the middle of the run between banks, and Djet has it off the #1/#2 rail. Return goes from the regulator, across the back of the engine/rear firewall, back down to the tunnel. @iankarr did a video on the install: https://youtu.be/IDFsZoI_W3g Pelican link for hose diagrams. For late model under-car routing look at the 1.8 diagram: https://www.pelicanparts.com/914/technical_...el_diagrams.htm |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:27 PM |
