QUOTE(r_towle @ May 18 2023, 07:17 AM)
If the pump is in front, the feed line (rubber) goes up the passenger long, along the back trunk wall, then connects to the fuel pressure regulator.
Off the regulator feeds the driver side injectors, then from there to the passenger side injectors, then back to the return line to the tank.
I guess it’s up to you, but the regulator is first, then injectors
Got that backwards. Pressure goes from the tunnel to the #3/#4 rail, across the top of the engine to the #1/#2 rail, then to the regulator. Ljet has the CSV in the middle of the run between banks, and Djet has it off the #1/#2 rail. Return goes from the regulator, across the back of the engine/rear firewall, back down to the tunnel.
@iankarr did a video on the install:
https://youtu.be/IDFsZoI_W3gPelican link for hose diagrams. For late model under-car routing look at the 1.8 diagram:
https://www.pelicanparts.com/914/technical_...el_diagrams.htm
