Help: tangerine racing ss fuel line install |
shredtherad |
May 18 2023, 08:00 AM
Member Group: Members Posts: 86 Joined: 17-May 22 From: Longmont, Colorado Member No.: 26,559 Region Association: Rocky Mountains |
I got the tank out, removed the old lines, got the fuel lines through the tunnel but I am stuck on how the engine bay lines work.
Anyone have any photos of how they worked that one? Or what the layout looks like? Also, anyone have a schematic on how the layout looks for the fuel pump relocation to the front under the car but the steering rack? I must suck at searching because I was unable to find what I was looking for... thanks all! |
sportlicherFahrer |
May 18 2023, 11:15 AM
Nothing to see here. Group: Members Posts: 1,088 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
Sweet! thanks mate. I assume a reducer is needed between the engine bay ss line and the fuel lines in the rail for the supply line? You're welcome! Sounds like you have the early large diameter feed line in the tunnel? The best solution is to use one of the reducers Tangerine sells, or something similar if you happen to have a local source. Stretching the small hose to the large line can damage or fatigue the hose causing leaks, and clamping a large hose to the smaller tube will almost always result in a leak. Up to you on how and where you want to fit a transition in. https://tangerineracing.com/shop/ols/produc...e-adapter-piece |
shredtherad |
May 18 2023, 11:30 AM
Sweet! thanks mate. I assume a reducer is needed between the engine bay ss line and the fuel lines in the rail for the supply line? You're welcome! Sounds like you have the early large diameter feed line in the tunnel? The best solution is to use one of the reducers Tangerine sells, or something similar if you happen to have a local source. Stretching the small hose to the large line can damage or fatigue the hose causing leaks, and clamping a large hose to the smaller tube will almost always result in a leak. Up to you on how and where you want to fit a transition in. https://tangerineracing.com/shop/ols/produc...e-adapter-piece Cool, I got a couple already! I planned a little bit. I think I got the layout down. but not sure what #1 in my photo is and there is a hose that was going to to the FP before I moved it #2 Attached image(s) |
DennisV |
May 20 2023, 08:39 AM
Member Group: Members Posts: 493 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Cool, I got a couple already! I planned a little bit. Did you get it complete? How did it go? What were the gotchas? I'm going to do this on our 914-6 next weekend and have a small window to get it done. Not sure how different the 4 and the 6 are other than the lines themselves. |
Lo-Fi Version | Time is now: 13th June 2024 - 03:47 AM |
