Help: tangerine racing ss fuel line install |
shredtherad |
May 18 2023, 08:00 AM
Member Group: Members Posts: 86 Joined: 17-May 22 From: Longmont, Colorado Member No.: 26,559 Region Association: Rocky Mountains |
I got the tank out, removed the old lines, got the fuel lines through the tunnel but I am stuck on how the engine bay lines work.
Anyone have any photos of how they worked that one? Or what the layout looks like? Also, anyone have a schematic on how the layout looks for the fuel pump relocation to the front under the car but the steering rack? I must suck at searching because I was unable to find what I was looking for... thanks all! |
Mikey914 |
May 22 2023, 04:38 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check the oil, check the trans fluid.
Pressurize the fuel system prior to starting by turning the key on to do so. Check for leaks! Pull coil wire and crank to bring oil pressure up. Reinstall wire to coil. Start I have had 1 transmission that at some point got turned sideways and lost a bunch of fluid. Forgot about that months later and installed it. It didn't last long. I'm sure there may be things that would be good to add, but these are the catastrophic things that can ruin your day. PS don't leave the key in the on position too long as you can damage points and coil. |
Lo-Fi Version | Time is now: 13th June 2024 - 05:47 AM |
