| kschulz2 |
May 26 2023, 08:46 AM
Newbie ![]() Group: Members Posts: 1 Joined: 15-August 09 From: Waukesha, WI Member No.: 10,680 Region Association: None |
I just followed Pelican Parts excellent instructions to replace my failing Ignition Switch ('74 LE, 242K miles). Replacement Switch Beck Arnley P/N 201-1076 from FLAPS DID NOT FIT, needed modification to install. Found this out, of course, when lower dash and steering column were disassembled to remove old switch.
All seems fine now, though my turn signal cancelling feature now needs some TLC. Attached File(s)
Beck_Arnley_replacement_switch___doesn_t_fit_May23.pdf ( 211.16k )
Number of downloads: 264 |
| technicalninja |
May 26 2023, 08:58 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Beck Arnley was once a excellent aftermarket choice.
Does anyone remember the Bap Geon import only parts stores? All gone (almost) and Beck Arnley has cheaped out. If you can find NOS old Beck Arnley your gloden. I dislike the new Beck Arnley and have stopped ordering them |
kschulz2 Ignition Switch Replacement May 26 2023, 08:46 AM
brant There was a ton of aftermarket (cheaply made) igni... May 26 2023, 09:13 AM
brant There was a ton of aftermarket (cheaply made) igni... May 26 2023, 09:32 AM
TheCabinetmaker That one pictured is for 75\76 only. Mismarke... May 27 2023, 08:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 12:35 PM |
