| kschulz2 |
May 26 2023, 08:46 AM
Newbie ![]() Group: Members Posts: 1 Joined: 15-August 09 From: Waukesha, WI Member No.: 10,680 Region Association: None |
I just followed Pelican Parts excellent instructions to replace my failing Ignition Switch ('74 LE, 242K miles). Replacement Switch Beck Arnley P/N 201-1076 from FLAPS DID NOT FIT, needed modification to install. Found this out, of course, when lower dash and steering column were disassembled to remove old switch.
All seems fine now, though my turn signal cancelling feature now needs some TLC. Attached File(s)
Beck_Arnley_replacement_switch___doesn_t_fit_May23.pdf ( 211.16k )
Number of downloads: 264 |
| brant |
May 26 2023, 09:32 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,295 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
There was a ton of aftermarket (cheaply made) ignition switches that people were replacing and having fail within in 1-2 months....
I thought the problem had gotten better recently but has been going on for 10 years. porsche started selling the switch again and the consensus was that all of the aftermarkets were crap... and the factory one at 3 times the price was the only one that was trouble free. there must be 50 threads about this on this site. you may want to order a factory one for your next try brant |
kschulz2 Ignition Switch Replacement May 26 2023, 08:46 AM
technicalninja Beck Arnley was once a excellent aftermarket choic... May 26 2023, 08:58 AM
brant There was a ton of aftermarket (cheaply made) igni... May 26 2023, 09:13 AM
TheCabinetmaker That one pictured is for 75\76 only. Mismarke... May 27 2023, 08:38 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 12:35 PM |
