| kschulz2 |
May 26 2023, 08:46 AM
Newbie ![]() Group: Members Posts: 1 Joined: 15-August 09 From: Waukesha, WI Member No.: 10,680 Region Association: None |
I just followed Pelican Parts excellent instructions to replace my failing Ignition Switch ('74 LE, 242K miles). Replacement Switch Beck Arnley P/N 201-1076 from FLAPS DID NOT FIT, needed modification to install. Found this out, of course, when lower dash and steering column were disassembled to remove old switch.
All seems fine now, though my turn signal cancelling feature now needs some TLC. Attached File(s)
Beck_Arnley_replacement_switch___doesn_t_fit_May23.pdf ( 211.16k )
Number of downloads: 264 |
| TheCabinetmaker |
May 27 2023, 08:38 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
That one pictured is for 75\76 only. Mismarked as fitting a 74.
kschulz2 Ignition Switch Replacement May 26 2023, 08:46 AM
technicalninja Beck Arnley was once a excellent aftermarket choic... May 26 2023, 08:58 AM
brant There was a ton of aftermarket (cheaply made) igni... May 26 2023, 09:13 AM
brant There was a ton of aftermarket (cheaply made) igni... May 26 2023, 09:32 AM![]() ![]() |
Lo-Fi Version | Time is now: 22nd November 2026 - 12:35 PM |
