> D-Jet Help - Please, Engine wont go below 3k
Cupomeat
post May 28 2023, 12:25 PM
missing my NY 914 in VA
Hello 914World, While I answer a lot of questions, I rarely post, BUT I am not well versed in D-Jet. I am having an issue that seems like it should have a simple answer, but so far, I am missing it.
So I am putting back together a 2.0L recently rebuilt for a friend and once I got it all back together, and once it started, the engine won't come down below 3K RPM. (IMG:style_emoticons/default/WTF.gif)
I am assuming this is some kind of Vacuum leak, maybe? It runs strong and smooth at 3K but doesn't go down with closed throttle.
SO, the engine is all new and I need to break in the cam, which, while 3k is probably ok, I'd like to get it sorted before I do that 15 min of 2k RPM.
I've checked all the vacuum lines and connections and see nothing wrong. I am thinking to get a smoke machine, or similar to try to see what I may have missed.
I am an L-Jet Guy with little experience with D-Jet and would LOVE some pointers or suggestions. (IMG:style_emoticons/default/pray.gif)
Thank you in advance and I did do some searches and haven't yet found anything like this.
CupO'Meat!
(the car is a 74 2.0L and I used Jeff Bowlsby's vacuum line diagram to double check)
Cupomeat
post May 29 2023, 09:01 AM
These are all great, THANK YOU!
I'll be going through all these suggestions today and answer/try to see what I can find.
SO, consensus is likely Vacuum leak, which is what I suspected.
OFF TO FIND IT!!!!
- Lo-Fi Version Time is now: 6th July 2025 - 12:04 PM
