Torsion bar Adj. ???? |
Mike Wofford |
May 31 2003, 11:07 AM
Member Group: Members Posts: 68 Joined: 29-April 03 From: Olympia, Wa. Member No.: 629 |
I have had my car up on jackstands doing a brake job and the exhaust. After lowering the car back down the drivers side of the car set up higher the the pass. I have rolled the car up and donw the driveway and the rear has evened out but the drivers front is still 1 1/2" higher than the passenger. any suggestions or tricks that would even the front back out.
Mike |
Bleyseng |
May 31 2003, 11:18 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Did you adjust the tbars?
Do you have adjustable rear spring perches? maybe a clip slipped. You can look to see if a rear spring is stuck or out of the register the spring fits into. If it isn't in the correct spot the spring sits wrong and the car is then tillted. Geoff |
Lo-Fi Version | Time is now: 12th June 2024 - 07:35 AM |
