porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Have a 911 temp insert I'am fitting to a 914 fuel gauge,I have 2 inserts but only one works but connecting power and earth to battery,needle go's straight to full reading is that correct ?.
If thats correct I want to test with sender,presuming if I connect sender to "G" on the rear of the gauge and earth the body of sender before applying heat to it ?. This isn't going in my car as I have all the 911 gauges sorted in my "6" conversion but a good winter project inside with the heating on (IMG:style_emoticons/default/biggrin.gif) . TIA ,cheers. ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Sounds correct so far. I've known a few folks that put a temp sender in boiling water to check the gauge.
I haven't had a temp gauge ever partially go bad on me. It's always the sender that seems to fail. |
porschetub |
Sounds correct so far. I've known a few folks that put a temp sender in boiling water to check the gauge. I haven't had a temp gauge ever partially go bad on me. It's always the sender that seems to fail. Thanks ,I'am the most unlucky guy with old VDO gauges,so will see how I go . Stopped buying used 911 tacho's as have had 1 fail not including the silver dot that came with the car. Currently looking @ a change to the gauge driver in my original gauge ,module uses modern tech and solders in to the old board with becomes redundant after fitting,got it from Bob @ ashlocktech ,top guy to deal with. As far if I can tell this temp gauge will pin out to max with power and ground connected but when the sender is in the system it should return to zero then rise when heat is applied..... hopefully. |
Lo-Fi Version | Time is now: 17th June 2024 - 04:54 AM |
