| Justinp71 |
Jan 22 2005, 12:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
I have a 75 914 and the transmission won't stay in 1st gear and is sometimes hard to shift into 2nd. If i replace the tranny with another one, is there a certian year I should buy? Can you convert the earlier year 914 or a 911 901 trans to fit the later 914's?
| skline |
Jan 22 2005, 12:45 PM
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California |
Check your clutch adjustment, unless its grinding really bad going into 1st and second, I would check your clutch first. As for the transmission, you would be able to bolt any 73 up trans into the car with no modifications to anything.
Justinp71 914 transmissions Jan 22 2005, 12:24 PM
lapuwali You want what's called the side-shifter transm... Jan 22 2005, 12:50 PM
jr91472 http://www.914world.com/bbs2/h... Jan 22 2005, 01:45 PM
14Maschine I have a 75. She shifts into 1st while moving. You... Jan 22 2005, 01:54 PM
lapuwali Early 911s (up to '72) used the 901, which is ... Jan 22 2005, 02:53 PM
! All 914 transmissions are the same except for the ... Jan 22 2005, 07:15 PM
Justinp71 Is it easy to rebuild the side shifter 901 trans? ... Jan 22 2005, 11:14 PM
SirAndy <... Jan 23 2005, 12:20 AM
balthazar The side-shifter swap isn't that hard. I just ... Jan 23 2005, 10:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:45 PM |
