| Justinp71 |
Jan 22 2005, 12:24 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,647 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None
I have a 75 914 and the transmission won't stay in 1st gear and is sometimes hard to shift into 2nd. If i replace the tranny with another one, is there a certian year I should buy? Can you convert the earlier year 914 or a 911 901 trans to fit the later 914's?
| lapuwali |
Jan 22 2005, 02:53 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Early 911s (up to '72) used the 901, which is very similar to the 914 gearbox, except for the end of the case and the shifter mechanism. The 915 was used on '72-on 911s until well into the '80s.
Justinp71 914 transmissions Jan 22 2005, 12:24 PM
skline Check your clutch adjustment, unless its grinding ... Jan 22 2005, 12:45 PM
lapuwali You want what's called the side-shifter transm... Jan 22 2005, 12:50 PM
jr91472 http://www.914world.com/bbs2/h... Jan 22 2005, 01:45 PM
14Maschine I have a 75. She shifts into 1st while moving. You... Jan 22 2005, 01:54 PM
! All 914 transmissions are the same except for the ... Jan 22 2005, 07:15 PM
Justinp71 Is it easy to rebuild the side shifter 901 trans? ... Jan 22 2005, 11:14 PM
SirAndy <... Jan 23 2005, 12:20 AM
balthazar The side-shifter swap isn't that hard. I just ... Jan 23 2005, 10:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:23 PM |
