| robkammer |
Jun 22 2023, 12:05 PM
Robbo ![]() ![]() Group: Members Posts: 262 Joined: 7-January 21 From: Vermilion Ohio Member No.: 25,049 Region Association: NineFourteenerVille |
All: The doors on our 74 have really great fit on the outside, but rattle quite a bit. When I pull on the door it can be pulled in just about an eighth of an inch and the rattling and squeaking stops.
Haynes show striker plates that can be shimmed, but the 74 has a later style that has two rubber tabs instead of screws. Has anyone swapped styles and had good results? All of the rubber on the car was replaced during a restoration in 2014-2016 and it's had less than 3000 miles since, and always been garaged as well. Any idea would be helpful. Thanks! |
| Mikey914 |
Jun 26 2023, 09:33 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
Also notice the threshold is held down with a screw. Should really be a plastic push rivet, but you may not be able to go back if the screw made the hole bigger.
Attached thumbnail(s) |
robkammer door striker plate Jun 22 2023, 12:05 PM
914Sixer Adjust the striker. It should move in 4 direction... Jun 22 2023, 12:40 PM
porschetub
Adjust the striker. It should move in 4 directio... Jun 22 2023, 06:12 PM
robkammer I don't feel that's the right fix. The doo... Jun 22 2023, 05:38 PM
peteinjp
I don't feel that's the right fix. The do... Jun 22 2023, 06:23 PM
peteinjp A pic for reference.
Jun 23 2023, 06:08 PM
rick 918-S Take the 4 screws loose and tap the catch slightly... Jun 24 2023, 06:53 AM
robkammer Thanks Rick! So, I sent some pics to the Dr. A... Jun 26 2023, 06:48 AM
76-914 :thumbsup: Jun 26 2023, 07:59 AM
Mikey914 The door seals are backwards. The door rubber is n... Jun 26 2023, 09:23 AM
Mikey914 The inner door also has no seal bulb on it. It sho... Jun 26 2023, 09:29 AM
robkammer
Also notice the threshold is held down with a scr... Jul 2 2023, 12:37 PM
Mikey914 Rob I suspect the threaholds could still use the ... Jul 2 2023, 01:16 PM
robkammer Hey everyone: Put original Porsche gaskets in the ... Jul 21 2023, 11:39 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:31 AM |
