| scotty b |
Jan 22 2005, 06:43 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I'm guessing someone has built a fuel injector tester by now. I have an old Bosch mechanical injector tester and was thingking today about making work on electrical ones, problem is I don't know how much voltage/amperage they get. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I doubt they get a full 12v, and I really don't want to ruin any trying to find out (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) .HELP?
| scotty914 |
Jan 22 2005, 08:02 PM
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
yes i built one, not very hard. one way is two build a 5 volt regulator on a switch, the hook it up to the injector, push the button to open the injector. if you are not sure how to build a 5 volt reg search on subtech on the internet they are a rc model sub ( as well as other remote stuff ) place that sells all sorts of electronics, they are currently being disturbuted by mikes sub works, look for the bec or some thing like that. it will supply one amp at five volts with a supply of 8 to 24 volts.
i built one and used it to open my injectors to pump cleaner through em, had the reg very hot to the touch by being open and drawing i think two amps for like 5 mins at a time. never even warmed the injector, but i think they run off of 3 to 4 volts in our cars |
scotty b Fuelk injector tester Jan 22 2005, 06:43 PM
McMark Injectors get about 1.5 volts from the FI, but I... Jan 23 2005, 02:58 AM
DJsRepS Mine opened with an 9v transistor raido batt. Jan 23 2005, 08:54 AM
scotty b What about pressurizing the incoming fuel? Is it e... Jan 23 2005, 09:43 AM
scott thacher easy and safe way to get fuel or cleaner through i... Jan 23 2005, 11:38 AM
McMark Scott, that sounds like a damn fine idea. I have ... Jan 23 2005, 12:19 PM
Bruce Allert I use an old model railroad transformer to open mi... Jan 23 2005, 07:59 PM
r_towle ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:19 AM |
