On a wing and a flare, Detail image where body meets rear flare |
Shivers |
Jul 12 2023, 08:06 AM
Senior Member Group: Members Posts: 2,436 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
My rear drivers side flare took some damage in shipping. I’ve got the shape back, but the passenger side flare hints at the body blending into the flare at the top. Most of the pics I see here are shiny and of the whole car. Could someone with pics of their car being done please help me with this detail. Or a pic of a finished car with a good view of this would be great too. Thank you.
Drivers side Passenger side |
Literati914 |
Jul 13 2023, 09:12 AM
Senior Member Group: Members Posts: 1,479 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
If you need filler, which you will to some degree to help seal the weld seems and create a better contour transition - I recommend using a short strand fiberglass filler because it remains flexible (though when hard you’d not think so) and it’s better with not holding moisture. Home Depot carries quart cans of Bondo brand.. called ‘Bondo Glass’. Good luck.
Shivers |
Jul 13 2023, 11:24 AM
If you need filler, which you will to some degree to help seal the weld seems and create a better contour transition - I recommend using a short strand fiberglass filler because it remains flexible (though when hard you’d not think so) and it’s better with not holding moisture. Home Depot carries quart cans of Bondo brand.. called ‘Bondo Glass’. Good luck. . Thanks, I’ve used 3m’s Mar glass before. I’ll check out the bonds as HD isn’t that far away. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:31 PM |
