| basenji7 |
Jan 22 2005, 09:03 PM
Newbie ![]() Group: Members Posts: 21 Joined: 20-April 04 From: dallas, tx Member No.: 1,953 |
Does anyone have a hi HP plan for a '74 2.0L 914 engine rebuild? I want to get the max possible horespower out of it and retain the reliability. If someone has pushed it to the safe limit and can provide me w/the details i would appreciate it.
Currently fuel injected but I would like to entertain all avenues smilie Thanks, Darryl http://www.cardomain.com/memberpage/753901 |
| SirAndy |
Jan 23 2005, 12:19 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
unless you go for a warmed up camshaft, there's no use in using carbs. they won't be making more HP but *will* eat more fuel ... however, *if* you go with a more agressive camshaft, the stock FI won't cut it. your call, i guess. the bursch muffler is a good choice, what do you run for the heat-exchangers/headers? SSI HEs have a bigger dia. and help the engine to breath better. a well set up 2.0L (euro PCs/ euro compression) should get you in the 95HP (at the wheel) range, which is plenty for our little cars, if you know how to use it ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
basenji7 1974 2.0L Rebuild Jan 22 2005, 09:03 PM
SGB keep in mind that most mods change peak horsepowe... Jan 22 2005, 11:45 PM
SirAndy Jan 22 2005, 11:50 PM
basenji7 I'm running the Bursh exhaust from Pelican Par... Jan 23 2005, 12:12 AM
nebreitling displacement. add copiously. Jan 23 2005, 12:21 AM
basenji7 I was thinking somewhere in the 150hp range. Mayb... Jan 23 2005, 03:09 AM
newdeal2 Look into Jake Raby's 2270 kit that will be co... Jan 23 2005, 07:39 AM
MecGen Hey
Mines like this :
Web Cam - camshaft
Kobles E... Jan 23 2005, 08:08 AM
Dominic ... Jan 23 2005, 08:27 AM
DJsRepS Simple math here Max hp + Reliability = Jake Rab... Jan 23 2005, 09:24 AM
SirAndy ... Jan 23 2005, 12:10 PM
Aaron Cox ive seen this car.
http://memimage.cardomain.net/... Jan 23 2005, 12:23 PM
jd74914 so it actually exists http://ww... Jan 23 2005, 01:18 PM
basenji7 Jake Raby really seems to be the way to go. Does ... Jan 23 2005, 02:49 PM
anthony Jake will tell you that each engine is different b... Jan 23 2005, 03:20 PM
MattR Im not sure its fair to answer any engine question... Jan 23 2005, 03:32 PM
Bleyseng I have build a 95rwhp 2056 and it take more than j... Jan 23 2005, 03:59 PM
anthony I've been thinking of building a 2056 but I... Jan 23 2005, 07:08 PM
Bleyseng Forget runnin Djet if you do. A modified 2056 wit... Jan 23 2005, 08:07 PM
Jake Raby We made big head way this weekend with the "New En... Jan 23 2005, 09:10 PM
rhodyguy the d.d.+ sure seems to be in line with what i wan... Jan 23 2005, 10:06 PM
Jake Raby My bored cylinders will be available outright or o... Jan 24 2005, 10:41 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:16 PM |
