rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,083 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I am thinking about painting the case, valve covers and heads with a thermal dispersion coating to get rid of some heat more efficiently . Has anyone tried this before?
https://www.cerakote.com/shop/cerakote-coat...7/transfer-grey. Grey is ok, but would like black or silver 35 bucks for a sampler.... |
cassmcentee |
Member ![]() ![]() Group: Members Posts: 228 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California ![]() ![]() |
Woke up this morning with a thought regarding heat retention...
Been cleaning my split case halves for over a week now. Every time I think that they are clean (exterior) I am able to draw more grease/grime out and have to go at it again. Sort of like cleaning a dirty sponge, I honestly can't believe how porous these cases are. Doing the coating as you are makes so much sense! By sealing the case with the coating, you are effectively sealing the pores in the "Sponge" Now all of the areas where oil/grease would collect within the case faces are greatly reduced. Over time, build up will be greatly reduced and thus heat retention will be reduced as well. Thank you for this post as I am going to do the coating now as well! |
Lo-Fi Version | Time is now: 14th July 2025 - 11:37 AM |
