rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,083 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
Here is a link to part one:
http://www.914world.com/bbs2/index.php?sho...117&hl=2056 I decide my t1 oil pump in my 2056 was doing me no favors with a smaller than ideal OD. I still had the T4 oil pump from the 2.0 that was doing its job when I had a cam thrust bearing fail /knock, so I decided to pull it a part for inspection. I will perform some measurements and get it cleaned up, if it turns out to be in good shape. The pics look like a great core. ![]() |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,384 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
(IMG:style_emoticons/default/popcorn[1].gif) Can't wait for this to be fired-up. (IMG:style_emoticons/default/beerchug.gif)
rfinegan |
(IMG:style_emoticons/default/popcorn[1].gif) Can't wait for this to be fired-up. (IMG:style_emoticons/default/beerchug.gif) YEP, Getting optimistic again. With dreams of Octeenerfest, driving on the Dragon and LARGE dyno numbers! This is a dream right? |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,830 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
(IMG:style_emoticons/default/popcorn[1].gif) Can't wait for this to be fired-up. (IMG:style_emoticons/default/beerchug.gif) YEP, Getting optimistic again. With dreams of Octeenerfest, driving on the Dragon and LARGE dyno numbers! This is a dream right? @rfinegan watching and learning from your experiences, Hope to see you at Okteenerfest for sure!! at some point i need to reassemble my OEM motor that dropped the valve seat a couple years ago, and i am trying to decide if i can do that myself, i didnt crack the case i justhave to put the newly rebuilt original heads back on it and wonder if i need to lap the head if i keep the old cylinders and pistons in place, i assume i should. anyway we should get the 914s from SC and NC together and do a engine build how-to clinic! Good luck going forward 3x is a charm right?? |
rfinegan |
Lapping the heads can only be a good thing, and you get a chance to look at the cylinder bores and pistons/rings too. AS well as resealing the case to cylinders while you are at it....top end work should go pretty EZ for people with good repair skills, even if they are new for type 4 work...Just need simple hand tools and a torque wrench and some hi temp Curel T(green) or a small dab aviation sealer ...What could go wrong....
-Cheers. and thanks for the support (IMG:style_emoticons/default/popcorn[1].gif) Can't wait for this to be fired-up. (IMG:style_emoticons/default/beerchug.gif) YEP, Getting optimistic again. With dreams of Octeenerfest, driving on the Dragon and LARGE dyno numbers! This is a dream right? @rfinegan watching and learning from your experiences, Hope to see you at Okteenerfest for sure!! at some point i need to reassemble my OEM motor that dropped the valve seat a couple years ago, and i am trying to decide if i can do that myself, i didnt crack the case i justhave to put the newly rebuilt original heads back on it and wonder if i need to lap the head if i keep the old cylinders and pistons in place, i assume i should. anyway we should get the 914s from SC and NC together and do a engine build how-to clinic! Good luck going forward 3x is a charm right?? |
Lo-Fi Version | Time is now: 13th July 2025 - 04:31 PM |
