Clutch pedal travel excessive |
peteinjp |
Apr 10 2023, 06:53 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not wanting to put any undue pressure on the TOB I pulled the cable end as far forward as i could while pushing the clutch lever as far back and adjusted the cable with no free play. Tube is good, cable, pressure plate, flywheel etc all have about 30,000kms. Pedal stop is low and yet I have to push the pedal all the way to the floor to keep from grinding in 1st and reverse. I can not pull the pedal back at all as described in the factory manual. It works but barely- the travel is too far even with the cable adjusted with slight pressure on the shift fork lever.
It seems to me there should always be just the slightest play in the cable- no?? Any thoughts? Pete |
peteinjp |
Jul 17 2023, 11:48 PM
Just an small update- the KEP stuff has arrived so I thought I would post up some pics and weights.
As stated before I put the questionable stuff back in and have been running it like that. I removed the clutch pedal stop entirely and have had no issues with grinding etc. Situation is stable and reliable. But the pickup point is still low and with almost no play in the pedal i.e. T.O. bearing is probably riding the fingers of the pressure plate a bit. Good news is that both the pivot and rear main both seem to be holding oil. New stuff from KEP. I thought it was stage 1 but box says stage 2- not sure of the difference. Flywheel weighs in at 5.6kg/12.4lbs. Doesn't seem super light to me and I'm not sure of the original flywheel weight. Probably a good balance for a street car with the 2.7 rs spec cams. Aluminum shoe (or foot?) PP. Steel coated friction surface. 3.1kg/6.8lbs. KEP used to deal the Hi-torque starter but has dropped them and now deals WOSP. So It will be a while before I dig back into it all seeing as in its all working well at the moment. I will drop the motor this winter for dyno tuning and to get some paint work done at the same time. I'll check the condition of the current stuff and see if its gotten any worse. My guess is that it's fine as I'm sure there is no slippage. Best! Pete |
Lo-Fi Version | Time is now: 8th June 2024 - 01:15 AM |
