| 914Sixer |
Jul 22 2023, 06:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,453 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Thought I would show these because they are rarely seen, Fit on the front suspension point and attach to lower lip of FACTORY LE spoiler.
Attached thumbnail(s) Attached image(s)
| technicalninja |
Jul 23 2023, 11:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
Complete original hardware. Note color of plating on brackets and width of opening on tin clips. The clips slip over thick edge or spoiler easily. These brackets are bent 'square' at the small hole end, Marks are bent at an angle Thanks for the detailed picture. Where do the 10mm headed cad plated bolts with the large flat washers and the rubber washers fit? These are in the center of the pictures. |
| rgalla9146 |
Jul 23 2023, 12:52 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Complete original hardware. Note color of plating on brackets and width of opening on tin clips. The clips slip over thick edge or spoiler easily. These brackets are bent 'square' at the small hole end, Marks are bent at an angle Thanks for the detailed picture. Where do the 10mm headed cad plated bolts with the large flat washers and the rubber washers fit? These are in the center of the pictures. Those two are tightened from inside the front trunk through the latch panel. The rubber discs and large flat washers are to keep the interior of the trunk dry. Actually an 8mm tool. The two smaller ones are tightened from inside the front fenderwells through the latch panel as well. Same screw as above, just shorter. All four pull the spoiler against the body with the tin clips slipped onto the edge of the fiberglass. |
914Sixer Rarely Seen: LE Spoiler Braces Jul 22 2023, 06:35 PM
JeffBowlsby FS Mark? I can use a set for my CS Jul 22 2023, 06:44 PM
914Sixer Not for sale, contacted Peter at Restoration Desig... Jul 22 2023, 06:49 PM
JeffBowlsby I have an original LE spoiler Jul 22 2023, 06:50 PM
Van B A good American would ensure the rest of us can ge... Jul 22 2023, 07:29 PM
wonkipop
A good American would ensure the rest of us can g... Jul 23 2023, 01:43 AM
jim_hoyland What is the purpose of the braces ? Jul 22 2023, 07:34 PM
To brace the... Jul 22 2023, 07:42 PM
technicalninja Mark
Please put a ruler next to those and retake t... Jul 22 2023, 07:41 PM
914Sixer I will do the measurements tomorrow and post them ... Jul 22 2023, 08:06 PM
JeffBowlsby Here are my measurements from a few years ago Mark... Jul 22 2023, 11:05 PM
jim_hoyland How do they attach to the spoiler so the FG does r... Jul 23 2023, 08:27 AM
technicalninja
How do they attach to the spoiler so the FG does ... Jul 23 2023, 09:04 AM
wonkipop
How do they attach to the spoiler so the FG does... Jul 24 2023, 02:12 AM
914werke How do they attach to the spoiler so the FG does ... Jul 23 2023, 09:53 AM
rgalla9146 Complete original hardware.
Note color of plat... Jul 23 2023, 10:33 AM
TonyA
Note color of pla... Jul 25 2023, 01:15 PM
914Sixer I have seen 3 versions of the bracket. One versio... Jul 23 2023, 11:12 AM
87m491 Sometimes I find my lack of "mechanical commo... Jul 24 2023, 06:20 AM
JeffBowlsby I have been driving with my original spoiler, with... Jul 23 2023, 12:17 PM
technicalninja My father, who was a bad assed pilot and an indust... Jul 23 2023, 01:22 PM
JeffBowlsby The original LE spoiler is not fiberglass. It’s... Jul 23 2023, 01:36 PM
technicalninja Smooth on the inside and often the mold is pressur... Jul 23 2023, 02:31 PM
friethmiller :popcorn: My LE's spoiler wasn't original ... Jul 24 2023, 07:49 AM
friethmiller Ok, this is definitely original hardware. Once I ... Jul 25 2023, 08:08 AM
dr914@autoatlanta.com where did you get them Mark? Jul 25 2023, 10:13 AM
914Sixer George, I got them from you. They were listed on ... Jul 25 2023, 10:38 AM
TonyA Never mind Roy I looked at your other comment, I t... Jul 25 2023, 01:19 PM
rgalla9146
Never mind Roy I looked at your other comment, I ... Jul 25 2023, 02:51 PM
TonyA That's what I said in my head but spelled it d... Jul 26 2023, 10:15 AM
friethmiller Not to hijack this thread too much but I had a que... Jul 26 2023, 05:12 PM
JeffBowlsby That’s the vintage VPC aftermarket LE-style spoi... Jul 26 2023, 05:17 PM
friethmiller
That’s the vintage VPC aftermarket LE-style spo... Jul 26 2023, 05:27 PM
JeffBowlsby My Classics page link is in my signature block.
h... Jul 26 2023, 06:05 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:42 PM |
