scott_in_nh |
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States ![]() |
So I'm probably not the first or last, but I just took out my 914 to go to the store and the heater hose came loose, got sucked into the fan and took out some blades (IMG:style_emoticons/default/headbang.gif)
Is there a different fan for the 2.0 (74) or do they all use the same one? PN? I assume the engine has to be dropped - correct? I'll be posting a WTB, but feel free to let me know if you have one.... Thanks, Scott |
DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,841 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
Man Scott that sucks! the timing marks might be different but the fans are otherwise thesame there is an early and late with different boss that you have to make sure the mounting bolts are not too long and stick thru too far.
I am pretty sure you will have to pull the motor and trans. Phil - oh and get yourself a VW bus bird cage for that thing, this is why i have one now, i dropped a valve seat from a towel getting pulled in there and blocked air flow and the#3 seat came loose! Phil |
scott_in_nh |
Man Scott that sucks! the timing marks might be different but the fans are otherwise thesame there is an early and late with different boss that you have to make sure the mounting bolts are not too long and stick thru too far. I am pretty sure you will have to pull the motor and trans. Phil - oh and get yourself a VW bus bird cage for that thing, this is why i have one now, i dropped a valve seat from a towel getting pulled in there and blocked air flow and the#3 seat came loose! Phil Thanks Phil, your situation is worse! That must have been the worst feeling.... Did you replace just the fan or the assembly with the pulley? Early vs. late - which uses the longer bolts? I see PNs ending with 031 and 113, but don't know which matches what I have? |
Lo-Fi Version | Time is now: 1st August 2025 - 05:18 PM |
