| scotty b |
Jan 22 2005, 06:43 PM
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I'm guessing someone has built a fuel injector tester by now. I have an old Bosch mechanical injector tester and was thingking today about making work on electrical ones, problem is I don't know how much voltage/amperage they get. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I doubt they get a full 12v, and I really don't want to ruin any trying to find out (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) .HELP?
| scotty914 |
Jan 23 2005, 11:38 AM
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
easy and safe way to get fuel or cleaner through it
buy a fuel bottle for a msr gas stove, there are desinged with gas in mind, drill a hole in the bottom and drop in a screw in tire vavle from the inside, put the nut on and tighten. then drill another hole and install another fitting of choice to hook a fuel line to ( can use another tire valve witht he valve removed ) then just put some gas or carb cleaner like i did in. put the cap on and put 20 lbs of air pressure in the bottle, they hold 100 psi with out a problem. whats nice about this is you are only dealing with 3 to 30 ozs of fuel ( depending on bottle size and how muck you fill it ) and its completely electric less for spark reasons |
scotty b Fuelk injector tester Jan 22 2005, 06:43 PM
scott thacher yes i built one, not very hard. one way is two bui... Jan 22 2005, 08:02 PM
McMark Injectors get about 1.5 volts from the FI, but I... Jan 23 2005, 02:58 AM
DJsRepS Mine opened with an 9v transistor raido batt. Jan 23 2005, 08:54 AM
scotty b What about pressurizing the incoming fuel? Is it e... Jan 23 2005, 09:43 AM
McMark Scott, that sounds like a damn fine idea. I have ... Jan 23 2005, 12:19 PM
Bruce Allert I use an old model railroad transformer to open mi... Jan 23 2005, 07:59 PM
r_towle ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:00 PM |
