cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
Heat exchangers In VGC. Passed smoke test. All welds Intact. Ears Intact. I did notice that the a few of the captive nuts need to be replaced. I have ordered them and will replace all of them.
Triad 2.0 Dual outlet exhaust. I ran these for less than a year and switched to headers. Some cosmetic rust but absolutely solid. 914werks custom hanger Installed and removed. Didn't even take the car off the lift. Stains Steel J Tubes New muffler gaskets $1200/OBO More to come ![]() This case is stamped with GA in the 1.8/1.7 location. Saddles are good, main bearing bore in spec, has not been cut for thrust. 2.0 Rods I did not measure these. I don't use stock rods. But I'm willing to do that. $300 if you pick them up Pertronics 7mm spiral wound ignition wires. Have neve seen an electon. Looked out of place on a MSD distributor $25 +ship Attached image(s) ![]() |
technicalninja |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region ![]() ![]() |
I've sent 4 pms.
Received a quick response to the first then crickets... I want some of this stuff. Anyone know this member? Is he OK? If something has happened to him, I don't want to be a nuisance. @cgnj are you with us? |
Lo-Fi Version | Time is now: 8th August 2025 - 12:59 PM |
