Head removal while engine in car ?, Can heads be removed from engine while engine in car? |
pistonboy |
Jul 30 2023, 02:58 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
Can heads be removed from a 914 engine without removing the engine from the car? Thank you. |
Jack Standz |
Jul 30 2023, 03:19 PM
Member Group: Members Posts: 280 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
I'm gonna go way out on a limb here and say no. (IMG:style_emoticons/default/smile.gif)
At least not without a sawzall. Just pull the motor and transmission together, then you can get to the cylinder heads. Best wishes for a successful fix! |
porschetub |
Jul 30 2023, 04:02 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I'm gonna go way out on a limb here and say no. (IMG:style_emoticons/default/smile.gif) At least not without a sawzall. Just pull the motor and transmission together, then you can get to the cylinder heads. Best wishes for a successful fix! (IMG:style_emoticons/default/agree.gif) not a big deal to remove if fact IMO one of the easier bigger jobs on a 914 ,just make sure you pre-soak various nuts and bolts with penetrant spray ,exhaust head nuts require the most and the application of some heat helps so you don't strip them or snap the studs. Carefully mark wiring you remove and take photo's before you remove other stuff,get some snaplock bags and mark them in relation to where the fastenings came from. Good luck and take your time ,cheers. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:17 AM |
