Head removal while engine in car ?, Can heads be removed from engine while engine in car? |
pistonboy |
Jul 30 2023, 02:58 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
Hello
Can heads be removed from a 914 engine without removing the engine from the car? Thank you. |
914sgofast2 |
Jul 31 2023, 04:07 PM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I think some people just like to do things the most difficult way possible. It could probably be done, but who wants to spend hours laying on their back and fighting with every nut and bolt you need to remove to loosen and remove the exhaust system, intake manifold, cylinder tins, and then finally the head, just to say you changed a head without removing the engine from the car?
Superhawk996 |
Jul 31 2023, 09:40 PM
914 Guru Group: Members Posts: 5,891 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I think some people just like to do things the most difficult way possible. (IMG:style_emoticons/default/agree.gif) Ya’ all making it too complicated. Drain oil? Remove exhaust? External oil coolers? Those are choices to add more work. Not mandatory to remove a basically stock engine. Yea pic below is carbureted but it will all still come out as an assembly with FI. |
VaccaRabite |
Aug 1 2023, 06:41 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I think some people just like to do things the most difficult way possible. (IMG:style_emoticons/default/agree.gif) Ya’ all making it too complicated. Remove exhaust? Those are choices to add more work. Not mandatory to remove a basically stock engine. Yea pic below is carbureted but it will all still come out as an assembly with FI. Not being at all sarcastic. How do you remove the engine without pulling off the exhaust? Are you pulling the axles out of the car? If not how are you manipulating the shafts and CVs to get them out of the way? Zach |
Lo-Fi Version | Time is now: 6th June 2024 - 07:38 AM |
