> Degree of Difficulty? Replacing Rear Floorpans & Base of Inner/Outer Firewall
9144me2enjoy
post Aug 2 2023, 07:57 AM
Need some advice, looking at a 914 that overall structurally is in good shape except for the Rear Floorpans and Base of Inner/Outer firewall (Pics attached.) Is these repairs pretty difficult (1-10 scale) for someone thats has the skill set to weld/fabricate these areas and estimated cost if I was to have someone to do the labor? Is this something I should walk away from? There doesn’t appear to be any frame damage and the cars measurements all pull to stock specs. There is no engine/transmission which I would be replacing with either a built 2.0L or similar drivetrain. Suggestions…….hell hole and longs look good also the other troubled areas look good or have been addressed. Also one has to factor in how much my cost is starting off which is below $4500. Thoughts? Thank you
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Front yard mechanic
post Aug 2 2023, 12:21 PM
Passenger side long has some rot. You will need to remove the triangle to repair that portion also more than likely the firewall will need some kind of repair. Looks doable for the cost you are suggesting. Good luck
9144me2enjoy   Degree of Difficulty? Replacing Rear Floorpans & Base of Inner/Outer Firewall   Aug 2 2023, 07:57 AM
dr914@autoatlanta.com   we virtually do these once a week, not difficult w...   Aug 2 2023, 10:13 AM
9144me2enjoy   George thank you for your expertise comments, appr...   Aug 2 2023, 11:07 AM
Front yard mechanic   Passenger side long has some rot. You will need to...   Aug 2 2023, 12:21 PM
Superhawk996   Run away as fast as you can unless you enjoy metal...   Aug 2 2023, 12:24 PM
mepstein   Ask George how much he charges for that repair. Yo...   Aug 2 2023, 12:34 PM
9144me2enjoy   Expect the worse, hope for the best always seams l...   Aug 2 2023, 12:57 PM
rjames   Expect the worse, hope for the best always seams ...   Aug 2 2023, 02:40 PM
DaveB   For replacing the floor boards - it's what Geo...   Aug 2 2023, 03:33 PM
9144me2enjoy   https://photos.app.goo.gl/pCgzPzJR1crVeWQ47   Aug 2 2023, 03:45 PM
930cabman   I would walk away   Aug 2 2023, 03:48 PM
9144me2enjoy   Dave thanks for the insert thoughts! I agree w...   Aug 2 2023, 03:49 PM
Dustin   nm   Aug 2 2023, 03:50 PM
9144me2enjoy   You guys have hit on a lot of good points :agree:...   Aug 2 2023, 03:51 PM
Superhawk996   You guys have hit on a lot of good points :agree...   Aug 2 2023, 04:07 PM
930cabman   You guys have hit on a lot of good points :agree...   Aug 3 2023, 08:55 AM
914work   not difficult what so ever, :D :lol: :rolley...   Aug 4 2023, 07:54 AM
JoeDees   I agree with previous comments in that replacing t...   Aug 4 2023, 08:15 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 09:15 AM
