> Degree of Difficulty? Replacing Rear Floorpans & Base of Inner/Outer Firewall
9144me2enjoy
post Aug 2 2023, 07:57 AM
Need some advice, looking at a 914 that overall structurally is in good shape except for the Rear Floorpans and Base of Inner/Outer firewall (Pics attached.) Is these repairs pretty difficult (1-10 scale) for someone thats has the skill set to weld/fabricate these areas and estimated cost if I was to have someone to do the labor? Is this something I should walk away from? There doesn’t appear to be any frame damage and the cars measurements all pull to stock specs. There is no engine/transmission which I would be replacing with either a built 2.0L or similar drivetrain. Suggestions…….hell hole and longs look good also the other troubled areas look good or have been addressed. Also one has to factor in how much my cost is starting off which is below $4500. Thoughts? Thank you
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
DaveB
post Aug 2 2023, 03:33 PM
For replacing the floor boards - it's what George said.
I saw something in your picture that I wanted to point out. The frame under the hell hole behind the jacking point may need to be replaced or repaired. On mine, I ground the cover sheet metal off to find everything inside rusted. After dipping, you can see the damage from the hell hole which leads right into this area.
Tap the metal around that area in the 914 and listen for the thud when you go over the area I pointed out.
Sitting out in the Dalles for years ate out the 914 I picked up. It's not difficult to replace this damage if you have the time and place for it. If you can drill or punch an 8mm hole and do a rosette fill you're 90% there. Once all the paint and bondo was removed, I ordered about $4K in sheetmetal. I'll have several hundred hours into the bodywork when I'm done. I say that I'm on the extreme side of repairs, your milage may very...
DaveB
9144me2enjoy   Degree of Difficulty? Replacing Rear Floorpans & Base of Inner/Outer Firewall   Aug 2 2023, 07:57 AM
dr914@autoatlanta.com   we virtually do these once a week, not difficult w...   Aug 2 2023, 10:13 AM
9144me2enjoy   George thank you for your expertise comments, appr...   Aug 2 2023, 11:07 AM
Front yard mechanic   Passenger side long has some rot. You will need to...   Aug 2 2023, 12:21 PM
Superhawk996   Run away as fast as you can unless you enjoy metal...   Aug 2 2023, 12:24 PM
mepstein   Ask George how much he charges for that repair. Yo...   Aug 2 2023, 12:34 PM
9144me2enjoy   Expect the worse, hope for the best always seams l...   Aug 2 2023, 12:57 PM
rjames   Expect the worse, hope for the best always seams ...   Aug 2 2023, 02:40 PM
DaveB   For replacing the floor boards - it's what Geo...   Aug 2 2023, 03:33 PM
9144me2enjoy   https://photos.app.goo.gl/pCgzPzJR1crVeWQ47   Aug 2 2023, 03:45 PM
930cabman   I would walk away   Aug 2 2023, 03:48 PM
9144me2enjoy   Dave thanks for the insert thoughts! I agree w...   Aug 2 2023, 03:49 PM
Dustin   nm   Aug 2 2023, 03:50 PM
9144me2enjoy   You guys have hit on a lot of good points :agree:...   Aug 2 2023, 03:51 PM
Superhawk996   You guys have hit on a lot of good points :agree...   Aug 2 2023, 04:07 PM
930cabman   You guys have hit on a lot of good points :agree...   Aug 3 2023, 08:55 AM
914work   not difficult what so ever, :D :lol: :rolley...   Aug 4 2023, 07:54 AM
JoeDees   I agree with previous comments in that replacing t...   Aug 4 2023, 08:15 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:42 AM
