Electrics gone haywire ! |
63acornwall |
Aug 4 2023, 06:43 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
Yesterday was like a normal day . I started up my 914/6 Tribute ( original 1975 914 with a 1974 911 6 cylinder transplant running on Webers ) , ran down to the fuel station in daylight , turn indicators work fine . Came home and discovered that ;
horn does not work clock does not work sidelights do not work headlights do not emerge ( but high beam indicator light does) hazard lights do not work windscreen wipers do not work What does work is ignition light , starter , and turn indicators Had a look at the fusebox which is aftermarket with blade type fuses , random checked a few fuses eg headlamp motor , parking lights - all ok So I guess there is no power supply to those circuits into the fuse box if fuses OK All I can think of is that some multi lead part of wiring harness has come unfixed but where do I look , I dont fancy pulling spaghetti out in case car ceases to work altogether !! Advice please - my specialist is 80 miles away but will drive it there as a last resort |
technicalninja |
Aug 4 2023, 06:58 AM
Senior Member Group: Members Posts: 1,320 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 6th June 2024 - 03:27 PM |
