Electrics gone haywire ! |
63acornwall |
Aug 4 2023, 06:43 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
Yesterday was like a normal day . I started up my 914/6 Tribute ( original 1975 914 with a 1974 911 6 cylinder transplant running on Webers ) , ran down to the fuel station in daylight , turn indicators work fine . Came home and discovered that ;
horn does not work clock does not work sidelights do not work headlights do not emerge ( but high beam indicator light does) hazard lights do not work windscreen wipers do not work What does work is ignition light , starter , and turn indicators Had a look at the fusebox which is aftermarket with blade type fuses , random checked a few fuses eg headlamp motor , parking lights - all ok So I guess there is no power supply to those circuits into the fuse box if fuses OK All I can think of is that some multi lead part of wiring harness has come unfixed but where do I look , I dont fancy pulling spaghetti out in case car ceases to work altogether !! Advice please - my specialist is 80 miles away but will drive it there as a last resort |
87m491 |
Aug 4 2023, 06:59 AM
Member Group: Members Posts: 275 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States |
Generally the hazard light circuit is one of the most robust and least encumbered, ditto the horn, at least in cars as old that this one. Seems like time to dig out your multimeter. Since no fuses are blown, the break in the circuit is possibly up stream of the power block vs downstream. Hard to tell how far your feeds differ from the norm given the engine swap but a quick Google of 914 wiring schematic will turn up the originals which is probably where you should start.
Yesterday was like a normal day . I started up my 914/6 Tribute ( original 1975 914 with a 1974 911 6 cylinder transplant running on Webers ) , ran down to the fuel station in daylight , turn indicators work fine . Came home and discovered that ; horn does not work clock does not work sidelights do not work headlights do not emerge ( but high beam indicator light does) hazard lights do not work windscreen wipers do not work What does work is ignition light , starter , and turn indicators Had a look at the fusebox which is aftermarket with blade type fuses , random checked a few fuses eg headlamp motor , parking lights - all ok So I guess there is no power supply to those circuits into the fuse box if fuses OK All I can think of is that some multi lead part of wiring harness has come unfixed but where do I look , I dont fancy pulling spaghetti out in case car ceases to work altogether !! Advice please - my specialist is 80 miles away but will drive it there as a last resort |
Lo-Fi Version | Time is now: 6th June 2024 - 05:03 AM |
