> My cooling fan just got hosed!
scott_in_nh
post Jul 26 2023, 11:42 AM
So I'm probably not the first or last, but I just took out my 914 to go to the store and the heater hose came loose, got sucked into the fan and took out some blades (IMG:style_emoticons/default/headbang.gif)
Is there a different fan for the 2.0 (74) or do they all use the same one?
PN?
I assume the engine has to be dropped - correct?
I'll be posting a WTB, but feel free to let me know if you have one....
Thanks,
Scott
sportlicherFahrer
post Aug 8 2023, 09:46 AM
Nothing to see here.
Tin comes out through the top of the engine compartment. Takes a little effort to work past the compartment seal, but it should slip out of there. Just went through that motion recently while replacing my alternator... (IMG:style_emoticons/default/dry.gif)
The fasteners holding the pulley to the fan are best not removed while the fan is on the engine. IIRC, the bolt heads are on the back side of the fan and will spin if you're able to get the nuts on the front broken free. More headache than it's worth. Working the tin out from in front of the engine is your best bet to get the clearance needed for fan removal.
scott_in_nh
post Aug 8 2023, 09:56 AM
QUOTE(sportlicherFahrer @ Aug 8 2023, 11:46 AM) *
Thanks, I will let you know how it goes
scott_in_nh   My cooling fan just got hosed!   Jul 26 2023, 11:42 AM
DRPHIL914   Man Scott that sucks! the timing marks might ...   Jul 26 2023, 12:17 PM
SirAndy   oh and get yourself a VW bus bird cage for that th...   Jul 26 2023, 01:05 PM
scott_in_nh   Man Scott that sucks! the timing marks might...   Jul 26 2023, 01:24 PM
StarBear   Phil - oh and get yourself a VW bus bird cage fo...   Jul 26 2023, 02:34 PM
mepstein   I have one for sale if you need it. http://www.9...   Jul 26 2023, 12:53 PM
Porschef   No, you’re not the first... :rolleyes: Are you...   Jul 26 2023, 01:40 PM
scott_in_nh   No, you’re not the first... :rolleyes: Are yo...   Jul 26 2023, 02:13 PM
ClayPerrine   You don't have to drop the motor, but it makes...   Jul 26 2023, 02:51 PM
scott_in_nh   You don't have to drop the motor, but it make...   Jul 26 2023, 07:10 PM
DRPHIL914   oh and get yourself a VW bus bird cage for that t...   Jul 26 2023, 03:44 PM
DRPHIL914   https://www.ebay.com/itm/232899935766?chn=p...4YaA...   Jul 26 2023, 03:46 PM
Karl R   I used to time mine with a timing like and a mirro...   Jul 26 2023, 04:22 PM
scott_in_nh   I will definitely be installing a guard before it ...   Jul 26 2023, 06:14 PM
930cabman   Being reasonably new to all things 914, a screen w...   Jul 26 2023, 06:42 PM
SirAndy   Any input for /6 guys? We need bigger screens ......   Jul 26 2023, 07:54 PM
FlacaProductions   From @GregAmy via my notes: Piece of cake. The ...   Jul 26 2023, 07:58 PM
rhodyguy   Remove the engine lid.   Jul 26 2023, 08:02 PM
scott_in_nh   I was able to lower the tin in front of the fan, b...   Aug 8 2023, 08:59 AM
sportlicherFahrer   Tin comes out through the top of the engine compar...   Aug 8 2023, 09:46 AM
scott_in_nh   Tin comes out through the top of the engine compa...   Aug 8 2023, 09:56 AM
scott_in_nh   Tin comes out through the top of the engine comp...   Aug 8 2023, 04:43 PM
Shivers   [quote name='scott_in_nh' post='3094405' date='Au...   Aug 23 2023, 10:08 AM
StarBear   Ordered the Type 4 fan guard (plastic one). Will g...   Aug 8 2023, 12:01 PM
scott_in_nh   Ordered the Type 4 fan guard (plastic one). Will ...   Aug 23 2023, 09:42 AM
FlacaProductions   Ordered the Type 4 fan guard (plastic one). Will...   Aug 23 2023, 02:19 PM
scott_in_nh   6mm Thanks Brian   Aug 23 2023, 02:52 PM
technicalninja   I just pulled this fan off of my 75 1.8l Out the b...   Aug 23 2023, 11:15 AM
emerygt350   Look what I just added....   Aug 24 2023, 06:00 PM
- Lo-Fi Version Time is now: 1st August 2025 - 05:21 PM
