| iwuzazombie |
Aug 13 2023, 10:43 AM
Newbie ![]() Group: Members Posts: 15 Joined: 17-July 22 From: Los Angeles Member No.: 26,700 Region Association: Southern California |
Hello! Now i know there are a lot of posts on this topic. I have been reading through many of them which have helped me through quite a lot troubleshooting this.
I just want to confirm something. The blower isn’t operating. I have checked and found there is power at the plug (upper passenger side pole connector). I have cleaned the contacts on the control levers at the heater controls in the cabin including its grounds. I understand pulling that thing out is a huge PITA. What else should i check? And is it enough to check that there is power on that plug? I also did attempt to apply direct 12v to that upper passenger side pole but it still did not come on. Just want to make sure i am trying everything before i dig into what seems to be a huge PITA pulling that thing out. Thanks in advance! |
| Rob-O |
Aug 13 2023, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,297 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region
Have you bolted the control lever mechanism to the firewall? Many forget that part and I’m 99% sure that is the ground that completes the circuit.
| iwuzazombie |
Aug 13 2023, 01:23 PM
iwuzazombie 914 fresh air blower question Aug 13 2023, 10:43 AM
iwuzazombie
Have you bolted the control lever mechanism to th... Aug 13 2023, 08:52 PM
r_towle
Hello! Now i know there are a lot of posts on... Aug 14 2023, 05:14 PM
TRS63
Power at plug
Use a set of alligator clips and ap... Aug 14 2023, 11:54 PM
DRPHIL914
Hello! Now i know there are a lot of posts on... Aug 15 2023, 06:30 AM
iwuzazombie
Hello! Now i know there are a lot of posts o... Aug 20 2023, 05:57 PM
Steve My V8 914 had no fan controls, so I used this diag... Aug 15 2023, 08:09 AM
iwuzazombie
My V8 914 had no fan controls, so I used this dia... Aug 20 2023, 05:55 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 03:46 PM |
