> 2056 rebuild part THREE, GOT Data? Log works 3
rfinegan
post Feb 6 2023, 07:38 AM
Here is a link to part one:
http://www.914world.com/bbs2/index.php?sho...117&hl=2056
I decide my t1 oil pump in my 2056 was doing me no favors with a smaller than ideal OD.
I still had the T4 oil pump from the 2.0 that was doing its job when I had a cam thrust bearing fail /knock, so I decided to pull it a part for inspection.
I will perform some measurements and get it cleaned up, if it turns out to be in good shape.
The pics look like a great core.
technicalninja
post Aug 13 2023, 03:55 PM
Sounds healthy!
Pretty balanced for a first start as well.
I'm a huge believer in running it under load (driving) for the first couple of hours.
Medium acceleration but using compression braking whenever possible.
Trying to achieve the highest manifold vacuum I can (engine decel).
I'd want to drive it this afternoon!
I'm happy for you and a bit envious...
My 2055 is a few months away.
You might need those smaller idle jets you have!
For no load 2K I'd want to hit north of 13.5 and south of 14.5
rfinegan   2056 rebuild part THREE   Feb 6 2023, 07:38 AM
Superhawk996   Agree - looks like a pretty good core. Pin the ...   Feb 6 2023, 07:50 AM
rfinegan   Great link, this should be a sticky if its not the...   Feb 6 2023, 08:04 AM
rfinegan   Here are come pics of case split and inspections   Feb 6 2023, 08:33 AM
rfinegan   another of the saddle and low pin locator   Feb 6 2023, 08:35 AM
rfinegan   rear thrust again   Feb 6 2023, 08:37 AM
rfinegan   and a video : dJ_iKZHldNk   Feb 6 2023, 08:44 AM
DRPHIL914   so what are your impressions of your observations ...   Feb 6 2023, 09:09 AM
rfinegan   Phil, This build and the last build had a total o...   Feb 6 2023, 09:42 AM
DRPHIL914   Phil, This build and the last build had a total ...   Feb 6 2023, 10:13 AM
rfinegan   Here is the worst of the intake guide #1. The exha...   Feb 6 2023, 09:45 AM
914sgofast2   Here is the worst of the intake guide #1. The exh...   Feb 6 2023, 12:36 PM
rfinegan   I have a new local shop add new intake guides and ...   Feb 6 2023, 09:48 AM
rfinegan   My summary of this build: 1) OIL pressure problems...   Feb 6 2023, 09:53 AM
Jack Standz   Crankshaft float s/b .004" plus or minus .001...   Feb 6 2023, 11:31 AM
rfinegan   check in without seal and again once the seal is i...   Feb 6 2023, 11:32 AM
Geezer914   Rear main seal tool, use a block of wood. Go easy...   Feb 6 2023, 02:56 PM
porschetub   Rear main seal tool, use a block of wood. Go eas...   Feb 7 2023, 03:23 PM
rfinegan   GREAT info on the rear main seal. ..with mods ht...   Feb 9 2023, 01:27 PM
rfinegan   Happy day for a change in the garage A world memb...   Feb 14 2023, 03:16 PM
914sgofast2   From your picture of the engine case mounted in th...   Feb 14 2023, 03:51 PM
rfinegan   I linked to the Raby live stream in post 19 Now th...   Feb 14 2023, 04:38 PM
NARP74   What were your thoughts on the wrong oil? Why did...   Feb 14 2023, 03:46 PM
rfinegan   I was thinking the VR1 20W50 was not the best oil ...   Feb 14 2023, 04:32 PM
NARP74   I was thinking the ZR 20W50 was not the best oil ...   Feb 14 2023, 04:38 PM
rfinegan   Trying to keep the motivation up on this holiday w...   Feb 19 2023, 01:32 PM
rfinegan   RE: 2056 rebuild part THREE   Feb 19 2023, 01:38 PM
barefoot   You keep your tools in the dark ??   Feb 19 2023, 05:47 PM
rfinegan   Old trick of the trade...no one asks to borrow any...   Feb 19 2023, 06:45 PM
r_towle   This will be the third build? Curious about break...   Feb 19 2023, 07:21 PM
rfinegan   Rich, Yep this is # 3 and the $1000 dollar q...   Feb 20 2023, 07:04 AM
rfinegan   Heads are repaired with new intake guides and 3 an...   Feb 21 2023, 04:03 PM
Cairo94507   I have my fingers and toes crossed this motor purr...   Feb 22 2023, 08:35 AM
rfinegan   I will be having a sale on engine parts it it does...   Feb 22 2023, 09:36 AM
rfinegan   I did some detailed measuring on the con rod journ...   Mar 4 2023, 08:24 AM
914rrr   Lots of great info on this thread! Good luck...   Mar 4 2023, 08:59 AM
rfinegan   It took a while but I finally got a set of NOS KS/...   Mar 27 2023, 05:24 AM
rfinegan   Thanks to the generosity of a Kerry, world member...   Mar 27 2023, 05:29 AM
rfinegan   :headbanger:   Mar 27 2023, 06:26 AM
rfinegan   Add a VDO HEAD TEMP thermocouple under the #3 spar...   Mar 28 2023, 05:54 PM
VaccaRabite   Unless things have changed, the VDO head temp gaug...   Mar 29 2023, 06:09 AM
rfinegan   This way the sensor stays in place when servicing ...   Mar 29 2023, 07:18 AM
rfinegan   Never opposed to OE parts if you can get them....   Mar 29 2023, 11:11 AM
rfinegan   I may be CRAZY, but got a set of ML Cam bearings n...   Apr 7 2023, 11:06 AM
rfinegan   NEW KS 2.0 rod bearing are HERE....   Apr 7 2023, 11:07 AM
rfinegan   Just got a new tube of valve lapping paste...The o...   Jun 21 2023, 04:50 PM
porschetub   Just got a new tube of valve lapping paste...The ...   Jun 21 2023, 05:36 PM
rfinegan   KTM 125 top end upgrade in the background.....whil...   Jun 21 2023, 05:00 PM
r_towle   You keep learning all sorts of fun things!   Jun 21 2023, 05:33 PM
rfinegan   heads are disassembled cleaned and lubed and back ...   Jul 9 2023, 03:48 PM
rfinegan   The windage tray had the same old seals, so a new ...   Jul 9 2023, 03:56 PM
rfinegan   vintage bearings too   Jul 9 2023, 03:57 PM
rfinegan   here is a video of the camshaft end play WpUDEaOW...   Jul 9 2023, 03:59 PM
rfinegan   Measured the case, bearings and crank journals as ...   Jul 9 2023, 04:06 PM
Cairo94507   :popcorn: Can't wait for this to be fired-up. ...   Jul 9 2023, 05:49 PM
rfinegan   :popcorn: Can't wait for this to be fired-up....   Jul 10 2023, 06:57 AM
DRPHIL914   :popcorn: Can't wait for this to be fired-up...   Jul 17 2023, 06:14 AM
rfinegan   Lapping the heads can only be a good thing, and yo...   Jul 17 2023, 07:30 AM
DRPHIL914   Lapping the heads can only be a good thing, and y...   Jul 17 2023, 07:57 AM
rfinegan   I did pin the shaft on the T4 oil pump. Drilled an...   Jul 10 2023, 06:02 AM
rfinegan   Playing with a thermal dispersion paint from Cerak...   Jul 17 2023, 05:30 AM
rfinegan   heads   Jul 17 2023, 06:14 AM
rfinegan   I updated ALL my videos on You tube for Robert Fin...   Jul 17 2023, 08:37 AM
rfinegan   Tonight I cleaned the carbon off the piston tops a...   Jul 19 2023, 04:28 PM
rfinegan   another   Jul 19 2023, 04:29 PM
rfinegan   one more   Jul 19 2023, 04:29 PM
BeatNavy   Looking really good, Robert! :thumbsup:   Jul 19 2023, 05:14 PM
rfinegan   Thanks Rob, Thanks for positive feed back, it is...   Jul 20 2023, 08:33 AM
r_towle   Thank you for doing such a great job documenting b...   Jul 20 2023, 07:58 PM
r_towle   TLDR, Did you use that paint on everything? Cool...   Jul 20 2023, 08:00 PM
rfinegan   TLDR, Did you use that paint on everything? I ...   Jul 21 2023, 05:35 AM
Cairo94507   :popcorn: :beer3:   Jul 21 2023, 06:18 AM
rfinegan   plan for the weekend... 1)Home made Jet Doctors fo...   Jul 21 2023, 07:10 AM
rfinegan   Darn, the engine yoke got me again. its touching t...   Jul 23 2023, 07:30 AM
rfinegan   DIY: Jet Doctor for idle jets or just by them fro...   Jul 23 2023, 11:11 AM
rfinegan   oil primer in progress...   Jul 23 2023, 02:30 PM
rfinegan   engine update..stubs and tins next...   Jul 23 2023, 02:34 PM
rfinegan   engine yoke mod...#3 cylinder   Jul 23 2023, 02:36 PM
rfinegan   cylinders hitting the the yoke frame   Jul 23 2023, 03:25 PM
rfinegan   Today I installer the blower housing, blower front...   Jul 24 2023, 04:24 PM
rfinegan   another pic of the bottom   Jul 24 2023, 04:27 PM
porschetub   another pic of the bottom looking great,thermost...   Jul 28 2023, 08:32 PM
rfinegan   Installed and torqued Clutch, Pressure plate and f...   Jul 24 2023, 04:29 PM
rfinegan   Today I recondition push rod tubs to remove dents ...   Jul 28 2023, 05:48 PM
rfinegan   added right tins and distributor   Jul 28 2023, 05:52 PM
barefoot   added right tins and distributor Make sure yo...   Jul 29 2023, 06:54 AM
rfinegan   I may have to try to fit an aftermarket thermostat...   Jul 29 2023, 06:38 AM
rfinegan   Good eye. Not wanting to pull the alternator/cover...   Jul 31 2023, 05:45 AM
rfinegan   Add a PMO fuel regulator (purchased in the classif...   Aug 6 2023, 01:53 PM
rfinegan   install pics..all done under the car. including Wi...   Aug 6 2023, 04:23 PM
rfinegan   another view of the Tangerine clutch mount Gen 1 ...   Aug 6 2023, 04:26 PM
rfinegan   Lets see how I did... I add 5 gals of 93 octane t...   Aug 13 2023, 09:30 AM
rfinegan   SO... I think I spiked the module doing power bal...   Aug 13 2023, 10:00 AM
BeatNavy   Nice job, Robert! :Qarl:   Aug 13 2023, 11:15 AM
rjames   Excellent!! :beer1:   Aug 13 2023, 02:27 PM
Cairo94507   Congratulations! She sounds good. :beer2:   Aug 13 2023, 03:33 PM
technicalninja   Sounds healthy! Pretty balanced for a first st...   Aug 13 2023, 03:55 PM
rfinegan   I add a new Malory Module to my ignition system H...   Aug 16 2023, 10:45 AM
rfinegan   30 min or so run time so I better get some Fresh o...   Aug 16 2023, 10:47 AM
technicalninja   On a first run in like you just did I clean the pi...   Aug 16 2023, 03:28 PM
- Lo-Fi Version Time is now: 13th July 2025 - 05:04 PM
