Contracted 914 fever— is this the car to cure it?, What do you think of this ‘73 914 2.0 on Bat— pass or play? |
trylon |
Aug 9 2023, 11:06 AM
Member Group: Members Posts: 204 Joined: 9-August 23 From: Connecticut Member No.: 27,514 Region Association: North East States |
New to the forum and the car. Was pointed to it by an aficionado on The Samba— I have a ‘59 Karmann Ghia. https://www.thesamba.com/vw/forum/viewtopic.php?t=723793
He suggested that the people on this forum were the brain trust for all things 914 and that I should vet one here that has caught my eye on BAT: https://bringatrailer.com/listing/1973-porsche-914-113/ Any insight would be appreciated! |
Porschef |
Aug 13 2023, 04:12 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
If they’ll let you, you can remove (possibly) the cheesehead screws on the bottom of the rocker along with the little nut and bolt front and rear. Pulling it out slightly should give you a strong indication whether or not further investigation is necessary. Otherwise just lay next to the car and have a look, if they don’t have a lift available.
But start with the battery tray and support, and of course the hell hole. Enjoy (IMG:style_emoticons/default/beerchug.gif) |
930cabman |
Aug 14 2023, 04:58 AM
Advanced Member Group: Members Posts: 3,144 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
If they’ll let you, you can remove (possibly) the cheesehead screws on the bottom of the rocker along with the little nut and bolt front and rear. Pulling it out slightly should give you a strong indication whether or not further investigation is necessary. Otherwise just lay next to the car and have a look, if they don’t have a lift available. But start with the battery tray and support, and of course the hell hole. Enjoy (IMG:style_emoticons/default/beerchug.gif) Basically a "must have" when looking at these. Take your time, because this tells much about the state of structure with the 914. If the screws come out(often they are rusted in) and the underside (structure) looks good, you are off to the races |
Lo-Fi Version | Time is now: 7th June 2024 - 04:25 PM |
