| DennisV |
Aug 15 2023, 06:08 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 867 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I've run into a couple challenges while replacing our brake system.
The new master cylinder has a single pole contact, whereas the original had 2-pole. I read somewhere that you just leave one wire detached. Do you lose some functionality doing that? ![]() I am having a hard time getting the plastic lines that run to the fluid reservoir to naturally land in a position where they would connect. The old lines appear to be identical to each other. Whereas the new lines are different from each other with different part numbers found in the factory parts catalog. Has anyone else run into this? These came from Porsche and I triple checked the numbers on the bag against the catalog. I inserted them into the master cylinder per the indication of the factory parts catalog. I have done all sorts of twisting and contorting but would have to bend one of them substantially to get them to align with the reservoir hoses. ![]() Thank you. |
| 914Sixer |
Aug 15 2023, 06:44 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,432 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Dennis,
I have a NOS 2 pole switch if you want OE. I have not seen new black lines but do they match the old lines when you lay them side by side? |
| DennisV |
Aug 15 2023, 07:00 AM
I have not seen new black lines but do they match the old lines when you lay them side by side? One of the new lines matched the old ones. Old ones were two matching lines. Not certain they were original or correct, but they were connected. New ones are each a unique part number and bend. |
DennisV Master Cylinder Replacement Challenges Aug 15 2023, 06:08 AM
mepstein “The new master cylinder has a single pole conta... Aug 15 2023, 06:28 AM
Superhawk996 Just a guess
I would think the line with the arr... Aug 15 2023, 06:46 AM
DennisV
I would think the line with the arrow that has mo... Aug 16 2023, 07:05 PM
Superhawk996
Maybe my expectations regarding fit and finish ar... Aug 16 2023, 07:28 PM
DennisV
EDIT: if you would be so kind, please post for o... Aug 19 2023, 12:58 PM
DennisV
EDIT: if you would be so kind, please post for ... Sep 2 2023, 09:04 AM
914Sixer Just my thinking , but they maybe selling the one ... Aug 15 2023, 07:41 AM
87m491 I just went through this trying to track down some... Aug 15 2023, 08:05 AM
Dave_Darling The two-pole switch has a signal and a ground. Th... Aug 15 2023, 09:46 PM
Superhawk996 Honestly - it doesn’t matter as long as lines ar... Aug 19 2023, 01:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 04:42 PM |
