> 3.6 993 engine installed into factory SIX, thoughts and guidance
jim dorociak
post Aug 13 2023, 05:59 PM
Guys I am collecting parts for my restoration. My car came without a drivetrain so I am looking at a collection of parts and what makes the most sense. I have 90% of a 95 993 engine that I have been collecting - one side of me says high compression dual plug, hydraulic lifters, torque and turn the key it starts right up without any drama. Or a short stroke - and you know where this goes - dual plug, special distributor, P/C's (not cheap) Carbs probably new PMO 46 (also quite a bill) and then the exhaust system with heat.
Does the factory front motor mount work on a 993 engine? I know the tin has to be married from 914-6 and 993 engine tin.
jdorociak@gmail.com
Jim
post Aug 15 2023, 08:43 AM
914-6 GT in waiting
We have a Ruf 5 speed 930 but I doubt my buddy will let me convert it to run backwards
Peter Dawe worked his magic on my WEVO trans so that must be why it works so well.
Steve
post Aug 15 2023, 09:05 AM
QUOTE(mepstein @ Aug 15 2023, 07:43 AM) *
The 930 gear boxes I have seen in a 914 required you to run it upside down, cut the trunk up and use a cable shifter. Plus the 930 trans is very costly. For me it was more trouble than it was worth.
ClayPerrine
post Aug 15 2023, 12:27 PM
QUOTE(Steve @ Aug 15 2023, 10:05 AM) *
That's the same reason I did not use a G-50. It required hacking up the trunk floor and running absurd axle angles.
jim dorociak   3.6 993 engine installed into factory SIX   Aug 13 2023, 05:59 PM
sixaddict   Jim: I am not an expert but to me using a Patrick ...   Aug 13 2023, 06:17 PM
SirAndy   This might give you some ideas ... http://www.914w...   Aug 13 2023, 06:21 PM
sixaddict   A P S…..add stiffening before you need it due to...   Aug 13 2023, 06:34 PM
targa72e   Engine choice and mounting is one thing. I think ...   Aug 13 2023, 10:05 PM
ClayPerrine   Some things I have found, and I have been there, d...   Aug 14 2023, 05:57 AM
SirAndy   The stock 901 transmission will bolt to the 3.6, ...   Aug 14 2023, 10:29 AM
mepstein   If you want a transmission that will hold up to a ...   Aug 14 2023, 06:14 AM
ClayPerrine   I found the link on the Pelican parts site for bac...   Aug 14 2023, 07:43 AM
jim dorociak   WOW you guys are so quick to shed light on the tas...   Aug 14 2023, 09:17 AM
ClayPerrine   WOW you guys are so quick to shed light on the ta...   Aug 14 2023, 10:02 AM
mepstein   WOW you guys are so quick to shed light on the t...   Aug 14 2023, 11:02 AM
ClayPerrine   You haven’t tried one that was properly built. ...   Aug 15 2023, 12:17 AM
Steve   I'm running the Martin Bott kit 916 with a ren...   Aug 14 2023, 10:25 AM
Steve   On another note... I had Dr. Evil build me a 914 ...   Aug 14 2023, 10:32 AM
Lucky9146   Great Thread here, and I'm all ears with my cu...   Aug 14 2023, 10:33 PM
Dr Evil   Yup, always comes down to the transmission. What g...   Aug 15 2023, 07:28 AM
mepstein   We have a Ruf 5 speed 930 but I doubt my buddy wil...   Aug 15 2023, 08:43 AM
JmuRiz   We have a Ruf 5 speed 930 but I doubt my buddy wi...   Aug 15 2023, 08:54 AM
Steve   We have a Ruf 5 speed 930 but I doubt my buddy wi...   Aug 15 2023, 09:05 AM
mepstein   We have a Ruf 5 speed 930 but I doubt my buddy w...   Aug 15 2023, 10:57 AM
ClayPerrine   We have a Ruf 5 speed 930 but I doubt my buddy w...   Aug 15 2023, 12:27 PM
eric9144   You haven’t tried one that was properly built. ...   Aug 15 2023, 02:10 PM
Steve   You haven’t tried one that was properly built....   Aug 15 2023, 02:20 PM
ClayPerrine   This almost smacks of religious conviction. (No I ...   Aug 15 2023, 03:01 PM
Steve   This almost smacks of religious conviction. (No I...   Aug 16 2023, 08:14 AM
bahnzai   I know I am in the minority here, but I am like Si...   Aug 15 2023, 07:05 PM
Front yard mechanic   Just curious how much does a Kennedy adapter for a...   Aug 15 2023, 07:15 PM
Steve   Just curious how much does a Kennedy adapter for ...   Aug 15 2023, 07:28 PM
bahnzai   Just curious how much does a Kennedy adapter for ...   Aug 15 2023, 07:33 PM
- Lo-Fi Version Time is now: 16th July 2025 - 12:25 PM
